September 23, 2026, 02:50:30 am
| | |-+  Swayaway 3” shorter
Author Topic: Swayaway 3” shorter  (Read 7541 times)
Rocket Ron
It's old school for a reason
« on: April 28, 2019, 08:46:40 am »
Anyone know if the 3” shorter sway away axles need early  or late  tube end castings ? I’m guessing they fit early short axle but can’t find any info on the website
Thanks in advance
13.12 @ 101.84
Grooving out on life
« Reply #1 on: April 28, 2019, 17:11:18 pm »
Hi Ron,
My 5 inch shorter used short end castings but the actual tubes could be early or late as you cut them to suit.
Not sure if you could use later end castings
Lee
« Reply #2 on: April 28, 2019, 20:26:24 pm »
Thinking about it, the long axle casting would potentially push the ladder bar mounts further in as well
Rocket Ron
« Reply #3 on: April 28, 2019, 20:57:06 pm »
Cheers lee
13.12 @ 101.84
Erlend / bug66
Global Moderator
SCC Event
« Reply #4 on: April 28, 2019, 22:00:41 pm »
It kind of depends on the splines?
Long castings are longer outwards? Tube is alway the same length.. 3” shorter are shorter on the tube side. And “always” short splines I think
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
