September 23, 2026, 03:45:18 am
Swayaway 3 shorter
Topic: Swayaway 3 shorter (Read 7545 times)
Rocket Ron
It's old school for a reason
Swayaway 3 shorter
April 28, 2019, 08:46:40 am »
Anyone know if the 3 shorter sway away axles need early or late tube end castings ? Im guessing they fit early short axle but cant find any info on the website
Thanks in advance
13.12 @ 101.84
Grooving out on life
Re: Swayaway 3 shorter
April 28, 2019, 17:11:18 pm »
Hi Ron,
My 5 inch shorter used short end castings but the actual tubes could be early or late as you cut them to suit.
Not sure if you could use later end castings
April 28, 2019, 20:26:24 pm »
Thinking about it, the long axle casting would potentially push the ladder bar mounts further in as well
Rocket Ron
April 28, 2019, 20:57:06 pm »
Cheers lee
13.12 @ 101.84
April 28, 2019, 22:00:41 pm »
It kind of depends on the splines?
Long castings are longer outwards? Tube is alway the same length.. 3 shorter are shorter on the tube side. And always short splines I think
