April 25, 2024, 04:53:12 am
LasseA
Technical stuff
Un even rear suspension
Topic: Un even rear suspension (Read 3364 times)
Garrick Clark
May 20, 2019, 15:13:34 pm »
Hi . I have a 67 bug.
Swing axle.
I think the inner spline mount for the torsion bar is looking like it's gunna strip which will let the bar rotate. A bit Dangerous really.
So what is the remedy to this.
Last Edit: May 23, 2019, 18:45:38 pm by GARRICK.CLARK
Air cooled Engine builder
dragvw2180
Re: Un even rear suspension
May 23, 2019, 19:12:48 pm »
Years ago I saw an adjustable torsion bar adjuster that welded in the middle of the torsion housing near the shift coupler. . Here is a video to give you an idea ,
https://www.youtube.com/watch?v=u38i1g1VT6k
Garrick Clark
May 23, 2019, 23:20:28 pm »
Hope I don't have to go that route. Looks a bad job to do
Garrick Clark
June 07, 2019, 12:36:43 pm »
Its definitely the fit between the inner spline mount in the chassis and the spline end of the bar. I think the splines on the end of the bar are too small.
UltraOrange67-2443
July 21, 2019, 22:01:28 pm »
Try another set?
1967 1200 2920cc EFI
Garrick Clark
July 23, 2019, 08:25:54 am »
I have. It's fine now. So beware when buying Sway away torsion bars.
UltraOrange67-2443
July 23, 2019, 21:22:16 pm »
I have sway a way bars.
I put grease on the splines as they felt loose.
OK now.
