July 22, 2026, 01:25:41 am
352240 Posts in 28934 Topics by 6923 Members
| |-+  Technical stuff
| | |-+  Rocker shims
Author Topic: Rocker shims  (Read 8827 times)
« on: June 03, 2019, 11:50:13 am »
Is there a limit on how much you can put between the head and the rockers.
I now have a 1.5 mm between them ( the thickest set you can buy) but need a bit more...
Did some of you combine several thicknesses under the rocker...
Thanks in advance.
« Reply #1 on: June 03, 2019, 17:42:44 pm »
I have just finished one that needed 3 x 0.030thou  under each block so 0.090 total[ nearly 2.3mm] I had to move rocker stud out of head a little to make sure shoulder that rocker block locates on had enough out of shims to work as intended but that was all.
« Reply #2 on: June 03, 2019, 18:24:38 pm »
Oh and also you might need taller valve covers  Roll Eyes
« Reply #3 on: June 03, 2019, 20:53:17 pm »
Thank you Richie.
Hm the taller valve covers I forgot...
« Reply #4 on: June 05, 2019, 08:47:08 am »
dipples also do the trick.  Roll Eyes
with thicker shims make sure to check the covers as you easily have not enough space...
« Reply #5 on: June 06, 2019, 01:39:14 am »
Is this caused by longer installed valve stem height?
« Reply #6 on: June 06, 2019, 06:53:38 am »
Ooooh sorry martin,
No this was caused by installing Porsche swivelfeet adjusters.
In an engine that was already in use... and did not want to modify the pushrod length.
« Last Edit: June 06, 2019, 07:58:04 am by Eddie » Logged
alex d
« Reply #7 on: June 06, 2019, 09:40:43 am »
did you grind around 1mm from the underside of the rockers to make space? with 911 adjusters everything gets tight if you don't
« Reply #8 on: June 06, 2019, 10:19:39 am »
Yep I did, even chamfer the underside a bit to make room for the swivelfeet to rotate/move.
Will post a picture tonight.
Have everything fitted and by chamfering a bit more, I have now enough space on the swivels..
Only thing to test is the valve cover now.
Dougy Dee
« Reply #9 on: June 06, 2019, 13:30:14 pm »
So... why did you add the swivel feet adjusters?
« Reply #10 on: June 07, 2019, 10:50:43 am »
Always straight contact to the valve, does not need a perfect valve geometry to work properly, so easier to set up.
Porsche uses them.... although that can not be the reason to use them.. Grin
« Reply #11 on: June 07, 2019, 12:23:43 pm »
I have an extra NOS Berg set for sale if anyone’s interested. Beef ones don’t need clearance grinding of the rockers.
