September 27, 2026, 03:53:35 am
| | |-+  Request for EFI N/A owners
Pages: 1 [2] Print
Author Topic: Request for EFI N/A owners  (Read 23127 times)
baz
« Reply #30 on: July 16, 2019, 12:48:06 pm »
How’s the fuel pressure? First time out with my new engine when it had one those small glass fuel filters on it, the filter started plugging up killing the engine. After that it got an oil filter as a gas filter (similar to a 356) and problem solved.
Pressure is OK, initially I had it set too high at high 40s, adjusted it down to 43 and it doesn't move from there while running or stalling. I've an internal pump and aeromotive filter.
Spoke to rr guy again today, hopefully have a slot for me next week. Reckon I'll leave it alone until then, apart from maybe cutting the tip off the silencer box
I will prevail.
Martin S.
« Reply #31 on: July 17, 2019, 11:59:45 am »
Check your aeromotive filter.
baz
« Reply #32 on: July 17, 2019, 13:25:29 pm »
Why do you suspect the filter? If there were filter problems wouldn't it show on the pressure gauge?
I will prevail.
baz
« Reply #33 on: July 24, 2019, 19:48:24 pm »
Got to the bottom of the leaning out problem, fuel map was way too low at idle and the start fuel map was keeping it alive until it phased out at 6000 turns.
I will prevail.
Pages: 1 [2] Print
