October 13, 2026, 20:04:26 pm
| |-+  For sale!
| | |-+  VW - 51 street racing beetle
Author Topic: VW - 51 street racing beetle  (Read 2555 times)
Jukkis Maki
« on: August 05, 2019, 15:29:20 pm »
Maybe the world's most iconic VW street racing beetle?
Genuine -51 steel body with OG lids, instruments, bumbers, doors etc.
- Custom-made 6 - point rollcage for this car. Autometer + VDO gauges. Ultra thin windshield and
 carbonate windows. Aluminium door panels. -69 shifter housing with billet joints.
- Jaz fuel tank and Carter hipo fuel pump with Summit pressure regulation + filter + new fuel lines.
 Optima Redtop. Composite seat, Blazercut and regular fire extinguisher, Sparco window net etc.
1951 floorpan with new panels and reinforcened rear fork for gearbox + solid gearbox brackets.
- Linelock, new brakelines, hoses and cylinders
- 29 mm torsion bars and adjustable spring plates from Sway-a-way + billet Easthill Welding spring
  plate covers. KONI adjustable rear and front shocks (modified by Kuplapaja)
- JAMAR 4" narrowed new front axle with new pushings, bearings + king and links pins and modified
  NOS -62 brakes. New NOS rear brakes Typ3.
Gearbox build by Mats Herrlander
- Rhino case, Weddle proring gears, JayCee spool, aluminium side covers
- unbreakable Karpiola axles
- R/P 3,88
- 3,75 / 2,22 / 1,56 / 1,22
- 17 starts.
82x94 engine
- Reinforcened AS41 case, genuine Gene Berg 82 mm axle and lighteden GB flywheel, Kennedy
  Stage 2 and Daikin disc, CB racing H-profile rods, modified C-65 cam, Thorsten Pieper lifters,
  compression 12,3:1
- Mahle hipo pistons and cylinders + Clavite 77 and Kolbensmith bearings. MSD 7AL2 ignition,
  distributor and coil
- Fullflow, Mellings oil pump and Mann oil filter system.
- SuperFlow heads (prepped) with stainless steel valves 48/38 mm, double springs (JPM) and
  titanium retainers (JPM). Pauter 1,5 rockers. 51,5 IDA Webers and Gene Berg 2” headers + stinger
  and Magnaflex silencer.
- CSP chromoly case stud kit and oil breather box, JayCee tubes and Scat sticks, NOS doghouse oil
  cooler from Typ4 etc. Uses pump gas 98 oct.
- Not a single part manufactured in China.
224 hp / 275 Nm with 7200 rpm. 11,79 / 177 https://www.youtube.com/watch?v=7gj-6Rp6WdQ
Shipping worldwide. NL and Belgium 800€, Lûbeck 600€ , California / USA 2000$. Sverige gratis frakt till STH.  Located in Finland
Turn key and drive! Registered for street use in Finland with regular 1600 engine
24900 €
Partial trade to Amarok is possible
