January 13, 2026, 08:25:00 am
67gtv220
Web86B cam / SCAT Lube a lobe lifters / ERCO triple springs
Topic: Web86B cam / SCAT Lube a lobe lifters / ERCO triple springs (Read 1824 times)
StrokerMcDell
August 08, 2019, 13:49:43 pm »
Brand new parts
Web Cam 86B camshaft with specified 112 lobe centres
(108 LC is standard)
These lobe centre config is ideal for turbo use.
£130 plus postage.
SCAT lube a lobe lightweight cam followers
With parkerised SLR coating
These lifters have a thin head that allows more lift and are wider to prevent scuffing. They have been reground by speciality cam grinder Steve Long (SLR) to give perfect 60* radius lifter head.
£70 plus post
ERCO triple valve springs with machined cromo retainers
These springs are superior to duals
Outer / inner / damper
165lbs seat pressure.
£55 plus post
__________________
10.67 at 123mph
10.89 at 125mph
"No man is an island"
....... except Barry
Barry Island is an island !
Fastorq is online now Report Post
ACE 116
10.67 @ 123mph York 2010
10.89 @ 125mph York 2009
Momentum 99octane pump gas
fahrvergnugen
Re: Web86B cam / SCAT Lube a lobe lifters / ERCO triple springs
January 09, 2026, 20:54:04 pm »
Is this typeIV or type1?
Will this work on a NA engine?
http://fast-air.skynetblogs.be/
