October 13, 2026, 07:37:31 am
Raptor Powerjet For Drag Racing
Topic: Raptor Powerjet For Drag Racing (Read 17646 times)
neil68
August 25, 2019, 02:52:18 am »
I have been experimenting with the JPM Raptor power jet kit and am looking for your experiences. 2332, 51 IDAs with Raptor 44 venturies and the most responsive jetting I’ve found thus far was F2, 135 main, 120 power jet and 220 air. I don’t have any smaller mains, but could try to find some (the only person who would share their combo on FB, had good success with 125 mains). My air-fuel gauge is still indicating a rich condition 10.5-11.5 on the drag strip. I’ve tried various power jets, but they don’t seem to affect it much: 80, 100 and 107.5. Also tried F4 tubes but that was even richer.
Power jets are supposed to work under guidelines of reducing the main jet 25%, and i’ve already done this: 180 to 135.
Anyway, your experiences would be appreciated!
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
jim martin
Re: Raptor Powerjet For Drag Racing
August 27, 2019, 06:27:34 am »
Neil I did not realize you were running this when we met at mission
For the great Canadian.
Let’s make a time to talk and I’m sure I can guide you through carb setup.
Jim
B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.812 at 145.26 mph
Sponsored by :
LUCAS OIL PRODUCTS
http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
neil68
August 29, 2019, 04:42:15 am »
Hi Jim, I was not running the power jet attachment at Mission Raceway because I was having difficulty jetting it. I was hoping someone in Europe may have this Raptor kit and would share their jetting.
I experimented some more at the drag races last weekend and I think I’m getting closer with: F2, 135 main, 120 power jet, 220 air, 60/120 idle. However, it’s still running rich, so I may need to pick up smaller main jets.
Neil
Dynojet Test:
PPRMicke
August 29, 2019, 09:06:29 am »
Hi Neil
How's your ignition? If it does not have enough ignition energy then the wrong AFR (rich)
On Andreas J engine with the same JPM fuel parts was 140 main F7 190 air (110 powerjet) mikuni jet) (42mm) (258 hp (2332cc)
On the 4 "engine, the only difference was the 180 main 44 mm (282 hp)
ignition old MSD 6Al (analog) the best
/// Micke
Last Edit: August 29, 2019, 14:17:35 pm by PPRMicke
RMS Boxer Service
August 29, 2019, 10:29:32 am »
When are your AFR meter showing 10,5-11, part throttle or full throttle??
If the engine runs rich at part throttle and in the middle rpm range then the
main jets are too big. Engine runs on idle curcuit up to appx 2500 rpm on IDA's
depending on engine set etc.
If the engine runs rich at full throttle in upper rpm level it can be both the main
jets and powerjets that's too large. How big are the jets in the powerjets??
/Rolf
neil68
August 29, 2019, 20:59:11 pm »
Micke: Complete MSD ignition with 6AL digital box, distributor, blaster coil, 8.5mm leads, etc. Beetle ran a 12.7 second 1/4-mile two weeks ago (without power jets), so I believe the spark is good.
Rolf: Running rich throughout the rpm range 10.5-12.0. Currently using 120 power jet, however, I also have 107.5, 100 and 80 power jets to experiment with.
I live at 1,000m elevation, or 700-800m track elevation depending where I race. MS230 heads, Wasp Stage 2, Raptor cam 274 degrees, 10.8:1 CR. I just reduced the idle jets to 60, and will see how that works at Friday’s drag races.
I noticed that everyone seems to use F7 emulsion tubes, which I haven’t tried yet.
Neil
Dynojet Test:
jim martin
August 30, 2019, 07:13:30 am »
It’s been awhile but if I remember f2 are going to run rich
I have to find old jetting info but I remember using a f7 it got rid of
Hesitation during progression and aloud for better top end jetting
Sponsored by :
LUCAS OIL PRODUCTS
RMS Boxer Service
August 30, 2019, 11:09:16 am »
What about fuel pressure ?? Are you sure it's not too high??
IDA´s are really sensitve to fuel pressure.
/Rolf
neil68
August 30, 2019, 23:05:45 pm »
Fuel pressure regulator was set at 3.0 psi, however, I will double- check!
Neil
Dynojet Test:
jim martin
September 01, 2019, 06:09:37 am »
We need to back up here , Neil you say best responsive jetting , I’m going to say brakes on
And let’s back up . It’s all about combo gearing to motor if your looking for response with a 44 vent depending on gearing and
Cam heads ect there may not be enough airspeed through carbs causing week or poor signal.so drivability can be a issue.
This may be why your having issues, and adding a third jetting stage is possibly causing more issues .you need to break it down into multiple States of tune .fuel jets first. idle /cruise , mid and finally top end , adjust tip in with pump shot
And fine tune with air,
I love tunning and this is a huge topic , Neil I will recommend to step back , dial car in without the 3rd jetting stage
And get it nailed without raptor power jet then add the system in
Sponsored by :
LUCAS OIL PRODUCTS
PPRMicke
September 01, 2019, 09:19:41 am »
Quote from: neil68 on August 30, 2019, 23:05:45 pm
Ps 2.5 psi is better for the level (3.0/3.5 needle valve)
you can get a fuel pressure increase during take-off and up to 330 feet (g x fuel weight) weight of fuel in liters is 0.73 grams)
/// Micke
neil68
September 02, 2019, 23:39:53 pm »
Pressure is 2.8 psi and 3.0 mm needle valve.
So, in the meantime I managed to over torque one of the power jet banjo fitting and broke it! Will have to set them aside for a while.
Neil
Dynojet Test:
