September 27, 2026, 09:18:08 am
| | |-+  Head upgrade from O44 to Superflow
Author Topic: Head upgrade from O44 to Superflow  (Read 11394 times)
AlexB
« on: September 02, 2019, 22:19:17 pm »
Currently in the process of upgrading the engine from my drag car ( The Jagerbug)
I’m changing the 2276 (82x94) engine from Cb 044 heads to some secondhand superflo heads I picked up a while back
The Superflos have been flycut somewhat so have a chamber volume of 30cc which is pretty small, I want a final cr of about 12:1
Current deck height is 0.90 mm
My calculations so far take me to using a 1.5mm copper head gasket (gives another 11cc according to my maths) which gives a top end volume of 41cc
Using a 0.5mm cylinder spacer drops the deck to 1.4mm
According to the Jmr calculator this gives a CR of 12.2
Does this sound correct ?
Engine runs FK89 , 48 Ida’s and is not street driven - just want to up the breathing with the bigger valve better flowing heads
Cheers Alex
« Reply #1 on: September 03, 2019, 02:17:55 am »
I make that 12.4/1
Forget all the calcs for 1.5mm copper to cc, its just deck height in real world so
deck height is 0.9+1.5+0.5mm= 2.9mm[ which to me is way to much for a N/A race engine]
head cc 30
with 94x 82 on jmr calc shows 12.4/1
AlexB
« Reply #2 on: September 03, 2019, 07:21:25 am »
I make that 12.4/1
head cc 30
So with a deck of 1.4 and 30cc chamber I get a comp ratio of 15.3 /1
To drop that further would I be better off machining pockets /dishing the pistons ?
Cheers Alex
Erlend / bug66
Global Moderator
SCC Event
« Reply #3 on: September 03, 2019, 08:08:02 am »
If the superflos has been running a lot with 30cc chambers, they could be pretty tired.. Depending on the year of production, the aluminium is pretty "light"..
Hold a SF in one hand and a new competition eliminator in the other. The difference in mass is pretty obvious..
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
« Reply #4 on: September 03, 2019, 09:48:13 am »
Would you need valve notches as well? Do you include the cc for them as well in CR calculation?
AlexB
« Reply #5 on: September 03, 2019, 10:08:12 am »
Hadn’t considered valve notch capacity - although thought they might be necessary, I suppose a decent pocket machined
In the piston crown would solve the need for valve notches and decrease CR
AlexB
« Reply #6 on: September 12, 2019, 09:33:54 am »
Ok - so rather than increasing the deck, if I machine a 70mm dish 1.5mm deep in the piston crowns then it will gain 5.6cc into the combustion chamber, then keeping the deck at 1.4mm that gives 13.4 compression - sounds more reasonable ?
DaveN
« Reply #7 on: September 12, 2019, 18:03:28 pm »
If it was my engine, I would increase the deck height, notch the pistons accordingly  and the compression ratio is what it is. It’s a race motor so you’re going to be running race fuel so high compression ratios won’t be a problem.
Martin S.
« Reply #8 on: September 14, 2019, 14:14:33 pm »
For mine it was unshrouding the valve. Then, dishing the pistons to match.
