September 22, 2026, 22:40:54 pm
| |-+  For sale!
| | |-+  Rancho pro drag
Author Topic: Rancho pro drag  (Read 2997 times)
flatfire
« on: October 30, 2019, 13:33:07 pm »
For sale rancho pro drag. I bought this with the intention of running it in my racecar. I ended up sticking it in my cal looker. Unfortunately due to the close gearing and the construction of a pro drag. It doesn't make for a comfortable long distance trip
It was previously owned by John Walklett
Rhino Case with Gusset
Alum Gear Carrier
Alum. Nose Cone
OEM Bearings
Super Diff
H/D Side Plates (2)
Chromoly Pinion Plate  Nut
3.88 R/P German
Weddle Chromoly Gear Stack (1-4)
1st gear 3.78 2nd 2.21
3 gear 1.58 4th 1.14
1500 pounds sterling
Can be contacted on 07923 365567 or peterchristie65@googlemail.com Cheers Peter
« Last Edit: October 30, 2019, 14:05:16 pm by flatfire » Logged
flatfire
« Reply #1 on: November 21, 2019, 13:35:46 pm »
Now on ebay. Smiley
http://www.ebay.co.uk/soc/share?du=https%3A%2F%2Fwww.ebay.co.uk%2Fitm%2FVW-beetle-ghia-bus-type-3-Performance-Rancho-Pro-Drag-Gearbox-Swing-Axle-%2F264532083616&rt=nc&t=VW+beetle+ghia+bus+type+3+Performance+Rancho+Pro-Drag+Gearbox+Swing+Axle&spid=2047675&itm=264532083616&media=http%3A%2F%2Fgalleryplus.ebayimg.com%2Fws%2Fweb%2F264532083616_1_0_1%2F1000x1000.jpg&swd=2&shorten=0
