October 13, 2026, 18:47:34 pm
| |-+  For sale!
| | |-+  11 sec 1914 race engine
Author Topic: 11 sec 1914 race engine  (Read 2620 times)
big d chop
O/FF 16
« on: November 01, 2019, 14:15:53 pm »
[ Attachment: You are not allowed to view attachments ] Type1 1914 race engine
AS21 case ,full flowed,
DPR wedge mated crank & flywheel,
H-beam rods ARP bolts,
FK89 cam,
Magnum straight cut cam gears,
Manson push rods,
JayCee push rod tubes,
94mm Mahle barrels & pistons(barrels have been honed so all ready,
Gene Berg pump cover & 26mm oil pump,
Super Flow heads 44 x 37.5 ( Ported byGuy Bryant in the States) with matching manifolds,
CB 650 springs,
Scat pro comp rockers 1.4.1,
MSD Distributor and leads,
MSD 6AL Box,
Gene Berg bottom pulley,
All new bearings and Grant piston rings,
NOS 10lbs bottle & brackets, solenoids,pipe work & jets,
Engine was only stripped as it had been standing for a while and to check it over,
It ran 12.46 N/A & 11.59 with a 50 shot of gas in a heavy car with a bus box,
Just needs bolting together,no working out or machine work needed.
Cheep 11 second engine £4000, would prefer pickup or could take to slough swap meet
big d chop is online now  Report Post      [ Attachment: You are not allowed to view attachments ]
« Last Edit: November 01, 2019, 14:39:25 pm by big d chop » Logged
OFF 16
