October 12, 2026, 17:47:51 pm
| | |-+  Piston rings 88 mm mahle
Author Topic: Piston rings 88 mm mahle  (Read 5404 times)
Henrik Hagen
« on: November 24, 2019, 22:31:34 pm »
Hello
I have bought a set of 88 mm mahle piston but I am a little unsure which pistons rings goes where.
The top two ring are both 1.5 mm thick but different in color. One is dark Grey and the other is a light Grey.
« Reply #1 on: November 25, 2019, 17:27:38 pm »
Look @ profile of the ring (from end of ring)
One should have a bevel angle on ID of ring, this is top ring
One should have and "L" cut in OD of ring, this is 2nd ring and L goes upside down
good luck,
Jim
Henrik Hagen
« Reply #2 on: November 25, 2019, 21:04:46 pm »
Thanks for the answer. My rings only have the angle on the inside not the "L" on the outside.
Mmmm... 🤔 🤔
« Last Edit: November 25, 2019, 21:06:42 pm by Henrik Hagen » Logged
dangerous
« Reply #3 on: December 02, 2019, 22:51:58 pm »
the silver colour should be the top ring,
look under a magnifier, they look to have a moly inlay on the face against the bore.
