September 06, 2026, 03:26:46 am
352300 Posts in 28955 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  TIKIMADness getting ready to go fast in 2015
Pages: 1 2 3 [4] 5 6 ... 23 Print
Author Topic: TIKIMADness getting ready to go fast in 2015  (Read 492182 times)
67worshipper
« Reply #90 on: August 05, 2008, 23:00:28 pm »
very interesting thread here.good work. Wink
vw hot rod heaven
tikimadness
« Reply #91 on: August 10, 2008, 15:19:39 pm »
Pushed the car outside again to dust it off and to take some pictures next to Pauls oval.
It s obvious that the car should drop a little more Wink
Michael
NIDGAFWYT
« Reply #92 on: August 10, 2008, 15:39:12 pm »
Mike, can you show some pics, and maybe do's or don'ts about quick releasening the rear fenders. I want to do the same thing on my car for years, but pushing this little project forward Undecided
Thanks Dude.
Awesome Work.
tikimadness
« Reply #93 on: August 10, 2008, 15:44:18 pm »
Sure I will make some picture this week while working on the fenders
michael
NIDGAFWYT
Bewitched666
Bewitched
« Reply #94 on: August 11, 2008, 12:00:12 pm »
Drop the noseeeeeeeeee Michael,haha Grin
Fast vw beetle's rule
tikimadness
« Reply #95 on: August 19, 2008, 21:45:37 pm »
been working on the fasteners of the rearfenders
I use a dimpletool because I don't like the fasteners with the poprivets.
michael
NIDGAFWYT
« Reply #96 on: August 23, 2008, 17:04:11 pm »
I bought the tool as well, but on the bug i have poly fenders. Thanks for the fender-pics sofar. Really cool work Mike.
Prowagen
« Reply #97 on: August 23, 2008, 22:38:28 pm »
I was thinking about that also, surely with glass wings you could just chamfur the edges of the hold to give the same effect???
Looking good Michael, Your work is great. Is the garage your business?
Rob.
tikimadness
« Reply #98 on: August 24, 2008, 17:43:24 pm »
Rob.
thanks,no it's not my job I am a carpenter Grin
michael
NIDGAFWYT
tikimadness
« Reply #99 on: September 01, 2008, 16:50:00 pm »
Got some stuff today from AJ Sims today,
Intake
and boostcontroller
michael
NIDGAFWYT
« Reply #100 on: September 02, 2008, 15:54:35 pm »
Michael are you running a type 4 powerplant?
Yes Grin Why?
Michael
Interested thats all!  Grin
Have you more details on what you plan with the engine? Case, bore size, cc etc?
I will be running my old 2.4 engine nex year with a turbo.
And I am planning to build a brand new engine.Again typ4 but with pauter heads.
It probably will be 86x103 which is close to 2.9 liters.
The plan is to have the case machined for 6 studs per cilinder and for typ 1 lifters.
The rest of the enginespecs will be determend when I have contact and advise from the enginebuilder as I need some one to do the machining and to help me put it all together.
Michael
Hi Mike,
I'm doing a T4 as well (80 X 103), my heads are already done by Ron Fleming and prepared for 5 studs. I have a new T4 case that
needs to be prepped as well. Who is you (fav) machine guy ?
Harry
tikimadness
« Reply #101 on: September 02, 2008, 17:20:02 pm »
I am planning to have Udo Becker do all the machining.I used to go to Bas Motorsport but I don't think they do the 6 stud modification.
Also I only here good stories about Udo even when I was at Pauter this summer.
Michael
NIDGAFWYT
Marty
« Reply #102 on: September 03, 2008, 00:36:27 am »
and boostcontroller
He is STILL selling that counterfeit crap?   Roll Eyes
« Reply #103 on: September 03, 2008, 15:39:01 pm »
Michael
You confirmed my thoughts !  Grin Grin Grin
tikimadness
« Reply #104 on: October 05, 2008, 14:22:41 pm »
Not much progress lately.The only thing I did was change the cable that operates the gearbox selector.
And I bought a pair of headlightcovers from a 993 porsche.I am going to make them fit the headlight ring as a replacement of the oriinal headlight assembly
michael
NIDGAFWYT
tikimadness
« Reply #105 on: October 08, 2008, 05:03:25 am »
Finaly decided to loose the chrome trim
And finished the tabs to mount the fender on
Michael
NIDGAFWYT
Prowagen
« Reply #106 on: October 08, 2008, 09:31:58 am »
michael
Michael what gearbox you running, cable select?
Rob.
tikimadness
« Reply #107 on: October 08, 2008, 14:41:38 pm »
michael
Rob.
I am running a renault 25 UN1 gearbox.
This was the only gearbox that was affordable at the time I build the brown Tiki last year.Robert Jongen used to run one and it was able to hold around 400bhp without breaking.
NIDGAFWYT
Prowagen
« Reply #108 on: October 09, 2008, 12:39:30 pm »
Wow thats interesting, this is a 5 speed box right? So did you have to get an adapter plate or a new bell housing made to mate up to the engine bolt pattern? How easy was it to adapt the cable shifter? And does the gearbox rotate and drive the right way from standard or did anything have to be done like flipping the diff?
Regards,
Rob.
tikimadness
« Reply #109 on: October 09, 2008, 13:14:08 pm »
Regards,
Rob.
Hi yes it's a 5 speed box but I am not using 5th.
The diff has to be flipped wich is fairly straight forward if you know how to set preload and how to shim the diff.
I removed the original bellhousing of the renault gearbox then fitted an adapterplate so I could use the bellhousing of a typ25 bus.My 2.4 bolts up to this belhousing and I can use the normal beetle clutchcable set up.
Also if I have to go to heavier pressureplates I can easily change the clutch to a hydraulic set up.
As a shifter I am using the shifter of a 90s To#¤ta because it has an arm that moves forward when you move the stick to the left.This way when I move the shifter to the left I pull a cable which controls the gearselector for the 1st and 2nd gear.
Í will make some pictures this week to make things more asy to understand.
michael
NIDGAFWYT
Prowagen
« Reply #110 on: October 09, 2008, 14:18:14 pm »
Cool thanks Michael, would be good to get a closer look.
Cheers,
Rob.
tikimadness
« Reply #111 on: October 14, 2008, 21:43:21 pm »
Sanded the welded spots today,
For Prowagen:
This is the shifter I am using,
The lever going in the tunnel is for operating the gearselector.
Here is the nose from te gearbox,
The cable is not yet connected cause I am searching for a good cable to use.It will probable be a throttlecable from an outboard engine. Wink
Hope this explaines it a little,
michael
NIDGAFWYT
Martin Greaves
10.88@128.58
« Reply #112 on: October 14, 2008, 21:56:03 pm »
Hi Michael look good should be finish soon then. Grin
tikimadness
« Reply #113 on: October 14, 2008, 22:00:32 pm »
pfffff,I wish.
Hope to get the car running in time for the first drag day in Bitburg (Believe april 2009).
It's going to be a lot of work but I think it will work out allright.
Youre turbo is in good hands Grin Grin Grin
Michael
NIDGAFWYT
Martin Greaves
10.88@128.58
« Reply #114 on: October 14, 2008, 22:04:12 pm »
Cool one
Your going to love a turbo car. Grin
tikimadness
« Reply #115 on: October 17, 2008, 13:01:55 pm »
one gone one to go,
It is slow but its getting there Wink
Michael
NIDGAFWYT
67worshipper
« Reply #116 on: October 17, 2008, 19:23:19 pm »
Rome wasnt built in a day. Perfection takes time Wink good work and an interesting thread  Smiley
vw hot rod heaven
« Reply #117 on: October 17, 2008, 22:25:44 pm »
AWESOME WORK Mike.
« Reply #118 on: October 17, 2008, 23:29:52 pm »
Yep,I like it.Can't wait to see the finished car.
tikimadness
« Reply #119 on: October 18, 2008, 06:46:31 am »
Thanks guys Smiley
Michael
NIDGAFWYT
