July 23, 2026, 08:01:27 am
352243 Posts in 28935 Topics by 6923 Members
Latest Member: Lotus67
| | |-+  4.57 ring and pinion bus box.
Author Topic: 4.57 ring and pinion bus box.  (Read 17246 times)
Bad bug
« on: January 05, 2020, 06:13:58 am »
Good day All,
Does anyone know who has the fastest 4.57 ring and pinion 091 bus box in their drag beetle or road going beetle whether 5 speed or 4 speed.
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: January 06, 2020, 11:28:08 am »
Good day All,
Richie maybe?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Bad bug
« Reply #2 on: January 07, 2020, 01:31:50 am »
Would love if richie could jump in on this thread. I don't need to know his first through fourth gear ratio but i just want to know if he used a 4.57 ring and pinion in his 091 box.
mikko k
« Reply #3 on: January 07, 2020, 06:04:41 am »
4,57:1 r/p is the strongest and longest at 091 box.
What about it?
Bad bug
« Reply #4 on: January 07, 2020, 23:28:01 pm »
Strongest yes i know but what do you mean by longest.
mikko k
« Reply #5 on: January 08, 2020, 04:59:03 am »
Longest ratio to bus box available.
Bad bug
« Reply #6 on: January 08, 2020, 11:48:27 am »
Ok so do you have one of these units in your car, how does it drive and what is your mileage like?
Dougy Dee
« Reply #7 on: January 08, 2020, 14:04:20 pm »
There are gear ratio calculators that will tell you theoretical top speed however they wont tell you what top speed will be with a 2.2L oxyboxer engine or let you factor in a drag co-efficient for your bus/baja/street lump...
I've been following your enquiry on this site and the Samba. Your persistence flogging this course of questioning without supplying specifics of your build makes me wonder whether someone has cracked your log in and is trolling this and Samba for their amusement...
mikko k
« Reply #8 on: January 08, 2020, 16:38:16 pm »
I have one 091 under construction. It will be 50/50 strip-street, so gear ratios will be a compromise and mileage doesn’t play any role.
All Weddle gears inside, etc. Turbo engine about 4-500hp.
Bad bug
« Reply #9 on: January 08, 2020, 23:32:51 pm »
What does your first and second gear look like with your 4.57 ring and pinion.
Bad bug
« Reply #10 on: January 08, 2020, 23:48:36 pm »
No one is trolling and no one has cracked my login. I just want to get some personal info from persons in the USA and Europe who have gone this route.
Well about my oxy 2.2ltr engine. Heads are the new los panchitos with 9.5:1 compression ratio with webcam 86b, Doghouse fan shroud with thermostat and late model wide fan and fan ring, Pauter 1.4:1 ratio rocker arms,chromoly pushrod tube set to loose zero,80mm waterboxer crank 94mm revmaster sleeves with JE pistons, 48mm trijet dells, dubshop crank fired ignition with IGN 1A race coils engine will have fuel injection in the future with ducati throttle bodies.
I have yet to purchase an exhaust system because i want all my tins to fit perfectly.
mikko k
« Reply #11 on: January 09, 2020, 18:58:36 pm »
I don’t remember the ratios.
It all depends on your car power and weight, purpose of use, rear tyre size, etc.
Good type 1 gear box can handle your hp.
Bad bug
« Reply #12 on: January 09, 2020, 23:03:05 pm »
Will be running 25 inch diameter wheel on the rear of the car the car will also be turbo charged in the future.
Bad bug
« Reply #13 on: October 10, 2021, 00:06:19 am »
No one has cracked my login. I must say i have been persistent in getting some answers as i am not able to get answers from my fellow country men.
Bad bug
« Reply #14 on: October 10, 2021, 00:12:31 am »
Wow answered twice about the trolling.
