October 15, 2026, 05:25:50 am
| | |-+  4.57 vs 4.13 ring and pinion
Author Topic: 4.57 vs 4.13 ring and pinion  (Read 8895 times)
Bad bug
« on: January 18, 2020, 18:29:57 pm »
Good day everyone,
Which of the two 4.13 or 4.57 ring and pinion is the strongest for the 002 or 091 gearbox.
mikko k
« Reply #1 on: January 20, 2020, 00:10:54 am »
4.13? Do you mean 4.125 beetle gearbox ratio? It does not fit to bus box.
4,571 is the strongest ratio available to bus box.
3,875 is the strongest ratio available to beetle box.
Dougy Dee
« Reply #2 on: January 20, 2020, 13:33:50 pm »
Weddle makes a 4.13 for 002 boxes. About $1500USD
mikko k
« Reply #3 on: January 20, 2020, 23:07:44 pm »
Thanks for info. I didnt know.
Bad bug
« Reply #4 on: January 21, 2020, 23:17:59 pm »
They now have a 4.13 ring and pinion for the 091 bus box. I can't see why people would want to remove the 091 ring and pinion and replace it with this unit.
mikko k
« Reply #5 on: January 26, 2020, 22:41:24 pm »
People have different needs and I dont know why other people need to understand. Some wants 1835cc engine, other 2L and next one 3,4L Pauter turbo engine...
You need ring and pinion. You need to know why and which one... Good luck!
« Reply #6 on: February 14, 2020, 16:37:18 pm »
You need it to get a bus gearbox longer in ratio. Good for a bus on German streets
