September 23, 2026, 05:12:05 am
long clutch arms
Topic: long clutch arms (Read 28241 times)
Garrick Clark
long clutch arms
January 31, 2020, 15:07:05 pm »
Hi guys, IS there anyone selling long clutch cable arms for early style cross shafts. uk based
thanks
Last Edit: January 31, 2020, 15:26:22 pm by GARRICK.CLARK
Air cooled Engine builder
Re: long clutch arms
January 31, 2020, 22:06:14 pm »
I'm sure there is a guy on thesamba doing them.
I just bought an item on thesamba, it was posted Monday and with me on Thursday morning.
Flc
February 01, 2020, 08:57:40 am »
I think I may have one , I'll look later
Dougy Dee
February 01, 2020, 14:40:52 pm »
Search
on The Samba. At one time he had some Long Arm parts.
February 01, 2020, 15:30:16 pm »
Can they be extended by welding? Cut, extend, weld?
Flc
February 01, 2020, 16:46:24 pm »
Yes still got mine , pm.if your still looking, I got mine from the states , someone from the samba. Now using a later type box
Garrick Clark
February 03, 2020, 13:36:43 pm »
Hi guys, FLC.
Before I go further with the long arm .
Does it touch the underside of the boot floor and
what is the cable angle like when it comes out of the end of the conduit cable, plus I guess I'll be after a slightly longer cable
February 03, 2020, 14:28:27 pm »
Or you can modify the arm on the pedal side..
Garrick Clark
February 03, 2020, 14:36:23 pm »
Like extend the clutch arm or a longer cable hook.
February 03, 2020, 15:05:24 pm »
Quote from: GARRICK.CLARK on February 03, 2020, 14:36:23 pm
Won't it be shorter? THen you'll get more leverage on the cable
Garrick Clark
February 03, 2020, 15:23:31 pm »
got me thinking now, It must be either extend the clutch leaver or the pedal, not both, to be fair if I extended the clutch pedal a couple inches that might be better as the 67 pedals are close together. The 68 on pedals had more space between them
Flc
February 04, 2020, 00:02:24 am »
It uses the stock cable and clears the boot floor by a long way, I don't think they are massively longer, but the ratio did give a lighter pedal with a stage 1 Kennedy than the stock arm and clutch set up
gkeeton@zbzoom.net
February 10, 2020, 03:16:10 am »
CSP has Flat-4's version of the longer arm for the 16mm shaft. I think Bruce on the samba has been out for a while.
https://www.csp-shop.com/en/transmission/arm-clutch-release-141-719-1130-27511c.html
Flc
February 10, 2020, 09:33:31 am »
Hope this is ok? Link to some info , I'd sell my early long one or swap it for a 75 on long arm
https://www.thesamba.com/vw/forum/viewtopic.php?t=695084
