September 01, 2026, 19:00:31 pm
Latest Member: Lotus67
| | |-+  BRM wheel studs/nuts
Author Topic: BRM wheel studs/nuts  (Read 9818 times)
andrewlandon67
« on: March 30, 2020, 21:53:02 pm »
Ignore my last post about detailing alloys, I'm stupid and have a very hard time making up my mind, but I finally have made a decision and I'm getting a set of Flat-4 BRMs for my '67 this year. One thing I'm curious about is what studs should I use to be able to use locking lug nuts on them? Is there any specific stud length I need?
14.877 @ 88.85 mph
He who waves at 911 drivers
Andrew
« Reply #1 on: April 01, 2020, 19:49:19 pm »
I'll get a photo of mine, if it helps but they are older versions of those wheels. I suspect they be longer than you think you need.
andrewlandon67
« Reply #2 on: April 01, 2020, 20:05:33 pm »
So I contacted CB about it and they gave me some recommendations on which stud/nuts to use and also which locking nuts would work best.
14.877 @ 88.85 mph
brewsy
« Reply #3 on: April 01, 2020, 20:07:16 pm »
NICE!!! :-)
I used these (but Im in the UK)
https://www.heritagepartscentre.com/uk/AC601LB117-locking-wheel-bolts-m12x1-5-22mm-set-of-4-tapered.html
BUT as I still run drums allround they had to be shortened
Stephen schmidt
« Reply #4 on: April 02, 2020, 17:33:24 pm »
I'm using bolts on my flat 4 BRM's, so need for studs and all that jazz. Makes it simple when I store the car on its stock wheels for the winter.
andrewlandon67
« Reply #5 on: April 02, 2020, 18:07:56 pm »
I'm also hoping to try running my car on slicks once or twice this year, and my local dragstrip requires studs/nuts to be used with slicks.
14.877 @ 88.85 mph
andrewlandon67
« Reply #6 on: May 14, 2020, 21:11:00 pm »
SOOOOOO I've been digging around online as a way of keeping myself entertained while I count down the hours until I can actually go work on my car, and I seem to have found some conflicting opinions on the subject of threaded vs press-in lug studs... I've seen some people say that thread-in studs are fine for most applications, but others say that they're completely useless and dangerous... I'm having a hard time sorting through the BS and I want to make sure I don't wind up making my car a deathtrap by using the wrong hardware to install my wheels soon. Please help!
14.877 @ 88.85 mph
« Reply #7 on: May 15, 2020, 07:35:41 am »
If you are even thinking about using slicks then use press in studs on rear, on front screw in studs with some thread lock work fine
baz
« Reply #8 on: May 15, 2020, 12:28:22 pm »
I had threaded studs in mine and they were junk and gave me all kinds of grief. I switched to verbus press in studs, its not a big job to fit them.
I will prevail.
« Reply #9 on: May 15, 2020, 15:32:40 pm »
Agree, press in studs are far superior to the screw in. I had the machine shop spot face the back of the drum so the stud pressed in 100% square to the face of the disc/drum. That also adds a little clearance from the back of the stud to the internals of the brake drum
Lee
andrewlandon67
« Reply #10 on: May 15, 2020, 18:04:20 pm »
Lee
Thanks for the advice! I guess for the time being I'll use what I have and save up for some better press-in studs and nuts to go with them.
14.877 @ 88.85 mph
