October 12, 2026, 14:35:00 pm
Bolt The 56 Rag Top
Topic: Bolt The 56 Rag Top (Read 11589 times)
santacruzxxx
Bolt The 56 Rag Top
April 03, 2020, 11:26:50 am »
Picked up a new project a couple of months back. It's a 56 Rag imported from Misourri in the US. My daughter has named him Bolt!
Body has been dipped and E Primed and is super solid for a 60 year old car. Heater channels, 1/4 panels, doors, etc all super solid. RHD dash has been installed at some point and done to a high standard.
Needs little bits of welding here and there and 2 new floor pan halves.
Last Edit: April 03, 2020, 11:31:13 am by santacruzxxx
santacruzxxx
Re: Bolt The 56 Rag Top
April 03, 2020, 11:32:13 am »
OG front wings with bullet indicators (no semiphors as it's a US model).
santacruzxxx
April 03, 2020, 11:34:03 am »
Picked up an IRS rear end and fabbed some alignment tools for the IRS brackets to be installed on the floorpan.
santacruzxxx
April 03, 2020, 11:37:01 am »
Little bit of repair work underneath front end where the top of the beam sits against the body.
santacruzxxx
April 03, 2020, 11:38:29 am »
[ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] Front heater channel closing panels needed a little repair work.
Last Edit: April 07, 2020, 21:49:14 pm by santacruzxxx
April 03, 2020, 15:35:41 pm »
Very nice body shell. Was it on eBay recently?
What’s your plans for it?
santacruzxxx
April 03, 2020, 22:57:01 pm »
Thanks and yes it was on Ebay Sept/Oct last year. Had to wait a while before I picked it up as the NOVA registration hadn't been completed.
Plan is for a full nut and bolt resto, IRS rear end, Lowered, rims, built engine/gearbox and then drive!
santacruzxxx
April 07, 2020, 13:14:13 pm »
Rear of heater channel had been caved in (probable used as a jacking point!). Drilled out the welds, straightened the panel, rust proofed and welded back in.
