November 03, 2026, 18:50:06 pm
| |-+  For sale!
| | |-+  Pair orig. italian 48 IDF
Author Topic: Pair orig. italian 48 IDF  (Read 2179 times)
Ovaltom
« on: April 12, 2020, 20:17:22 pm »
Modified from Engine Plus to 44mm Venturi and 5 Bypassholes.
Here the description from the engine plus site...
Quote
With this modification, the carburetor is modified so that it corresponds to the flow behavior of a 48IDA carburettor, and this with a better suitability for everyday use than with the legendary IDAs.
The following changes are made:
The carburetor housing (not just the cover!) Are completely spindled up to approx. 2mm in front of the throttle valve. A venturi with a larger outside and inside diameter is used. A fifth bypass hole ensures better transition behavior.
Modified throttle shaft for more flow and special idle jet holders.All bearings,gaskets etc. are less than 2000km.
Carbs are in really good condition.
Price 1150€
oval57@t-online.de
[ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
« Last Edit: April 12, 2020, 20:36:34 pm by Ovaltom » Logged
