October 28, 2026, 16:37:38 pm
352330 Posts in 28962 Topics by 6929 Members
Latest Member: Hanibal1
| | |-+  1385 supercharged engine
Author Topic: 1385 supercharged engine  (Read 13273 times)
samotorsport
« on: April 26, 2020, 21:19:23 pm »
So it is time to build a new engine for my 67 Herbie
It was my first aircooled project , some things i wouldn’t do nowadays anymore. For example the engine lid is a 65 now , one day it is going to be all 67 again , but thats not the point right now Smiley
It needs a new engine for next year as the one installed right now is almost done.
The base is a 1200 cc industrial engine.
Going to be a big bore 1385 cc engine
Stock 64 mm crank and con rods . 83 mm Pistons
Case is already prepared for full flow
And the fuelpump place is prepared to support the supercharger bracket
The charger is going to be an AMR500 , fed by a 40 DCOE , but my idea is to only use it as a cool looking throttle body and the fuel is going to be injected by a free programable EFI .
The heads are going to be 1300 DP , they need a full rebuild , seats guides out , wekding up cracks and so on , so plenty to do
Camshaft remains stock
EFI most probably a Speeduino .
My goal is to have a oldschool looking supercharger setup
But running just like a stock modern engine .
andy198712
« Reply #1 on: April 26, 2020, 21:47:35 pm »
nice, what are your plans for charge cooling? are you injecting before or after the SC?
samotorsport
« Reply #2 on: April 26, 2020, 21:51:02 pm »
My plan is to inject as close to the inlet valve as possible .
I plan on modifying stock inlet elbows by welding on aluminium adapters to put nozzles on them .
No cooling is planned , max boost will be 15 psi / 1 bar .
I hope to be around 90 hp and good torque , max 5000 rpm
andy198712
« Reply #3 on: April 27, 2020, 10:08:26 am »
if you don't fancy making them the injected VW manifolds are exactly as you mention but then i think you may need to look at what injectors they take?
Thats gonna be a really nice drive!
have you seen this?  https://www.shoptalkforums.com/viewtopic.php?f=3&t=151261&start=195 its a 1300 with AMR500
samotorsport
« Reply #4 on: April 27, 2020, 10:11:45 am »
Yes i know about the original injected ones , they may be hard to find around here.
But i got elbows , aluminium and a welding machine .
Will see which way to go .
No i didn t know that built , but will have a closer look to it for sure .
Thanks a lot
samotorsport
« Reply #5 on: May 04, 2020, 06:36:44 am »
Valve seats are out , now comes the tricky part to weld them all up
brewsy
« Reply #6 on: May 04, 2020, 12:47:37 pm »
Nice.
Are you going to keep stock sizes?
samotorsport
« Reply #7 on: May 04, 2020, 12:48:39 pm »
Yes stock size valves , hd single springs
