November 02, 2026, 05:11:44 am
Latest Member: thunder_bac
| | |-+  oil pump machining for oring
Author Topic: oil pump machining for oring  (Read 9374 times)
« on: May 01, 2020, 18:10:06 pm »
Hi,
Can somebody tell me the size of the groove to add an oring to a oil pump?
Oring is 70mm x 1.75mm.
Thanks  Wink
PPRMicke
« Reply #1 on: May 01, 2020, 18:57:02 pm »
same as O ring Width 1.75 deep 0,87mm  (can go down to 1mm)
/// M
« Reply #2 on: May 01, 2020, 19:01:31 pm »
/// M
Thanks,
So it sits flush with the pump case and seals with oil pressure?
samotorsport
« Reply #3 on: May 01, 2020, 19:25:52 pm »
No leave it out a bit , if you go down lets say to 1 mm with the groove , it still sticks out 0,75 mm if the o ring is a 1,75 thick one .
If it is flush with the pump case it will not seal .
RMS Boxer Service
« Reply #4 on: May 02, 2020, 18:35:11 pm »
The groove must be wide enough to allow the O-ring to be crunched when installed. If the groove is too narrow
the O-ring will have nowhere to go/expand and it will be cut when installed If the groove is too wide the O-ring will
loose crunch as it can wobble/snake in the groove.
Sorry for my bad tech terms, but try Google "O-ring groove design"
Here is a good site:
https://www.sealanddesign.com/page/o-ring-groove-design-metric
/Rolf
« Last Edit: May 02, 2020, 18:37:46 pm by RMS Boxer Service » Logged
« Reply #5 on: May 03, 2020, 19:22:20 pm »
/Rolf
That's what I've read, but being not a machinist, I wasn't sure I understood correctly  Wink
Thanks for the info.
I don't know if it is worthwhile to do it, but on the other hand, not a big job to do.
