September 23, 2026, 05:07:42 am
| |-+  For sale!
| | |-+  Racecar Type 4 Turbo Engine
Author Topic: Racecar Type 4 Turbo Engine  (Read 3930 times)
smull
« on: June 09, 2020, 14:11:48 pm »
78 x 96 forged, counterweight crank with Remmele front pulley, cro-mo flywheel and Stage 3 clutch cover. All balanced.
Custom J & E pistons on H beam rods, all match weighted.
Euro race barrels.
Euro race super racer heads with 911 style exhaust ports form new amc castings.
Webcams custom ground, hardweld cam with magnum gears and lightweight Type 1 style lifters.
Case is shuffle pinned and has ARP oversize through bolts and ARP head bolts along with sleeved lifter bores to take Type 1 lifters.
Autocraft 3 stage, dry sump pump.
Pauter roller rockers.
Custom built inlet manifold with charge cooler and 80mm throttle body.
Custom charge pipe from turbo to throttle body with BOV.
Twin scroll exhaust manifold fitted with twin tial 38mm waste gates.
Borg Warner S200SX turbo. Mini Alternator.
Omex 600 ECU & loom with all sensors and a custom made harness.
GFB electronic boost controller.
Proper Bosch 044 fuel pump with aem pressure reg.
The engine has not been run and needs a few bits to finish off; a set of injectors, a clutch disc and some hoses. The engine was designed and built to make approximately 500bhp once set up.
Reduced: £5500
Any serious enquiries or offers can be directed at Rob on 07309 658182 or rob AT rnjmotorsport.co.uk.
Alternatively, you can PM myself and I'll handle any queries that I can but in all honesty Rob has built this and will be happy to answer any questions from serious buyers.
« Last Edit: August 26, 2020, 18:59:45 pm by smull » Logged
A person is clever but people are stupid.
smull
« Reply #1 on: August 26, 2020, 18:59:58 pm »
Reduced. NOW £5500. Serious offers listened to.
smull
« Reply #2 on: September 15, 2020, 13:05:44 pm »
Pending.
smull
« Reply #3 on: September 17, 2020, 17:19:39 pm »
Sold.
Smiley
