October 13, 2026, 21:25:39 pm
Foreign object damage
Topic: Foreign object damage (Read 14163 times)
Garrick Clark
June 18, 2020, 15:14:33 pm »
Is there anyone within 100 mile of Preston, lancs that can fly cut some heads. Got a pair of heads cut for 90.5 that have damage to the squish area in the chambers. It would have to be a while I wait deal. I don't want to use a courier service .I've had parts damaged/lost/stolen in the past.
Air cooled Engine builder
BugBusBuggy
Re: Foreign object damage
June 18, 2020, 18:20:39 pm »
I reckon Danny at Reichspeed will be around 100 miles from Preston. Not sure if he can flycut heads, but his Facebook shows lots of machining work. Might be worth giving him a call to see if he can help. Found him helpful and easy to talk with, and would use him again. He's done maintenance, engine/gearbox swap and valve seats for me but no other head work, so I can't comment further than that.
Hope that helps,
Dave.
Last Edit: June 18, 2020, 19:11:58 pm by BugBusBuggy
If it breaks (and it probably will).... it's time for an upgrade...
Garrick Clark
June 18, 2020, 20:20:45 pm »
Ok thanks, I've found his number ,I'll ring tomorrow.
Garrick Clark
June 20, 2020, 16:45:59 pm »
Still need this job doing so I can move forward with it. I might do it myself. I have a cut down piston top with a through rod into the middle of the crown. I can glue sand paper to the crown , fit and old cylinder and spin it with a drill.
