September 12, 2026, 01:39:26 am
352303 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  Callook beam question
Author Topic: Callook beam question  (Read 9579 times)
GASBNR
« on: July 15, 2020, 09:30:16 am »
Hi guys I’m building the callook car I’ve alway wanted.
Did you guys remove the bump stop on beams
Did you run steering dampers?
I will narrow the beam 2inches because I’m running CB spindles early to late brakes.
Because of wheel choice.
SUPPORTING CAL-LOOK DOWN UNDER
« Reply #1 on: July 15, 2020, 20:39:18 pm »
Cut the stops off
GASBNR
« Reply #2 on: July 16, 2020, 04:37:50 am »
Thanks Bryan.
What about the steering damper bracket?
« Reply #3 on: July 16, 2020, 10:05:52 am »
I have always run a steering damper on narrowed beams. Bracket will need moving though iirc.
Looks like a really nice beam to start with
« Reply #4 on: July 27, 2020, 01:44:16 am »
Yes, Keep the bracket.
GASBNR
« Reply #5 on: July 27, 2020, 03:17:12 am »
Thanks Bryan 👍
GASBNR
« Reply #6 on: August 13, 2020, 09:33:58 am »
Thanks Lee. Just saw your post.
Will remove them tomorrow but Will try keep Them intact if I need them for roadworthy check we have here.
« Reply #7 on: August 13, 2020, 09:51:40 am »
Where are you going to narrow it from?
If you are fitting adjusters you can take the width from there and move the frame head brackets out.
If you are narrowing it from near the ends be careful where the inner bushes are
GASBNR
« Reply #8 on: August 13, 2020, 09:55:44 am »
My last set of berg adjusters to go in this.
GASBNR
« Reply #9 on: August 13, 2020, 11:35:42 am »
Doin the ends. 👍
Done a number of these.
Just trying to leave it w a factory look when the wheel is removed.
