November 02, 2026, 03:53:18 am
Latest Member: thunder_bac
| |-+  Technical stuff
| | |-+  Gearbox question
Author Topic: Gearbox question  (Read 11643 times)
samotorsport
« on: July 31, 2020, 19:19:15 pm »
So i ve got a question concerning your gearboxes . Those who are driving the car on both , street and track
Without any locked diff i loose a lot on the strip , on the other hand , with a 100 % locked one , driving around corners on the street isn t fun either.
Did you install a lsd ? Limited slip ? If so , what kind / brand n setting do you run ?
Best regards
Sam
« Reply #1 on: July 31, 2020, 20:04:57 pm »
I have a car with a quaife, one with spool[turbo car] and open with open diff[turbo car], all street drien and to be honest the spool drives pretty much like the quaife does when you are driving hard but quaife is much easier when driving slow/parking or pushing it!!! The open diff car just spins one tyre a lot Shocked Wink but is much better on roundabouts and general tight manoeuvring but it is a 1303 Cheesy
« Reply #2 on: August 02, 2020, 09:32:56 am »
A small side step,
Richie do you know where I can buy a good gearbox (or builder in Europe) good voor 200BHP.
I find it very difficult to find one. (with a website??)
Thanks in regrds
Eddie
« Last Edit: August 02, 2020, 09:34:32 am by Eddie » Logged
Jimbosmith
« Reply #3 on: August 02, 2020, 09:44:12 am »
A small side step,
Thanks in regrds
Eddie
Message John Walklett, i have had a box built by him. Highly recommend him, very helpful and will build to any spec i believe.
https://www.facebook.com/vwgearbox/
samotorsport
« Reply #4 on: August 02, 2020, 09:51:30 am »
Thanks a lot , so i guess , for a street driven car with power and occasional use on the drag strip , a LSD would be best option .
I still have a “AB” laying around , which could be used as a starting point .
But i hqbe to check the ratios , guess it is to weak for a 150 hp engine.
« Reply #5 on: August 02, 2020, 18:18:13 pm »
A small side step,
Thanks in regrds
Eddie
Thanks will have a look.
eddie
bean
« Reply #6 on: August 02, 2020, 18:46:02 pm »
only dealt with John Walklet once (few years ago now) - super helpful guy who diagnosed the most likely vause of my gearboxs issue over the phone and was spot on with his diagnosis to boot
« Reply #7 on: September 30, 2020, 18:22:19 pm »
A small side step,
Thanks in regrds
Eddie
Hi Eddie,
I know I'm late (almost two months after your question!) but Peter Englezos at Cogbox built my gearbox in my race car, and if I was having another one done, I'd use him again.
