September 09, 2026, 08:44:17 am
Latest Member: Bad Habit
| |-+  Technical stuff
| | |-+  Gearbox advise
Author Topic: Gearbox advise  (Read 12606 times)
samotorsport
« on: August 27, 2020, 00:57:06 am »
Looking for some advise on a gearbox for my project :
Mostly street use , very few non prep 1/4 mile runs , engine 2,1 - 2,3 liter with around 140 hp , leight weight bug with mostly stripped interior .
7x15 wheels in the back with something like 205/55/15 wheels plus minus ....
Not yet sure about putting in a lsd or not .
I still have an AB gearbox which could be used as a base .
This has the short 4,3 ratio which might be too short for my usage .
So what do you guys think ? 3,8 ratio ? What set of gears to put in and where to get them from ?
Or skip it and getting a Rancho straight away ?
« Reply #1 on: August 27, 2020, 02:43:45 am »
I have a Rancho pro street with 3.88 RP so basically a Superbeetle swing axel with a cheap Kafer bar. It’s been working great! Shifts are solid and no drama whether upshifting or going from 4th to 3rd at 100kmh, it just works.
Garrick Clark
« Reply #2 on: August 27, 2020, 11:25:37 am »
My KCR box has developed a whine, and doesn't stop till the bug stops. I hope it's just  a wheel bearing . Not looked yet.
Air cooled Engine builder
« Reply #3 on: August 28, 2020, 01:00:14 am »
I’ve had a bad rear wheel bearing but can’t recall the symptom.
How many miles/ years on your box?
Garrick Clark
« Reply #4 on: August 28, 2020, 12:03:37 pm »
About 1500 miles. Lol. Maybe the motor has damaged it somehow
« Reply #5 on: August 28, 2020, 22:07:36 pm »
That’s normal for a new transmission. Mine did that too and settled down with more use. What oil are you running?
Garrick Clark
« Reply #6 on: August 29, 2020, 07:41:16 am »
Just some basic EP90
« Reply #7 on: August 29, 2020, 15:58:45 pm »
Mine’s 5 years old now and seemed to get quieter every year.
spoolin70
« Reply #8 on: August 29, 2020, 17:37:22 pm »
Or your hearing is getting worse  Cheesy
Garrick Clark
« Reply #9 on: September 17, 2020, 11:02:36 am »
I'm wondering if it's coming from the 4 spider gears after I raised the rear up a spline. The Axle driveshafts are on a bit of a positive angle. That will promote oiling to the wheel bearings so doubt its those, but is the positive angle affecting it at the gearbox somehow. I'm going to re adjust the rear, to lower it, see if it changes anything apart from the height.
Andrew
« Reply #10 on: September 19, 2020, 08:19:16 am »
I found a traction bar was a great way to transfer gearbox noise up into the cab.
Garrick Clark
« Reply #11 on: September 19, 2020, 15:45:53 pm »
I've got solid front n rear mounts, this isn't  helping things..
