November 02, 2026, 05:11:47 am
Latest Member: thunder_bac
| | |-+  Lightened flywheel
Author Topic: Lightened flywheel  (Read 7233 times)
runningmonkey
« on: September 17, 2020, 13:48:43 pm »
Hi all
My motor has span a bearing so Iv got to take it out and rebuild.
I was thinking of possible upgrades to the engine once it out,
The motor is 2276 running CB performance EFI turbo kit, best iv done is 12.3 @ 109 mph, running 249 BHP at the wheels.
I had a few upgrades in mind, One being a possible lighter lightened flywheel, at present am running a standard lightened flywheel (which I believe is 5.7kg / 12.5 lbs) I have heard recently a lot of talk about more modern even lighter lightened flywheels, some weighing as little as 4 kg / 8 lbs
Was wondering if anyone knew who makes these and would it be a worth well upgrade to my engine.
Cheers John
PPRMicke
« Reply #1 on: September 17, 2020, 14:55:58 pm »
if you have planned to drive on the strip Then it will go slower with a lightweight flywheel
(here in Sweden we put more weight type steel pulley Because it will be faster 60 feet
