November 02, 2026, 05:55:10 am
Latest Member: thunder_bac
| |-+  Technical stuff
| | |-+  5x205 spindle link pink ->5x130 late brake drums
Author Topic: 5x205 spindle link pink ->5x130 late brake drums  (Read 14757 times)
« on: September 18, 2020, 16:57:24 pm »
i guys i need your tech advice
as you know i've a 61 bug with link pink front beams  so i'm on 5x205 pattern , but i would like to go in 5x130 porsche pattern
as i've a 1200cc in it , i don't want to go disc brake (unless I really have no choice) and with no adapter 5x205 ->5x130
so i would like to buy  68-> brakes drums redrilled in 5x130 , at rear it could be work without nothing to do  or just a little  spacer to add between the rear axle boltand the drums
but for the front it's a little different /difficult, it  seems that there is no bearing corresponding to the body of pink link spindle and the inner diameter of the brake drum it seems that the diameter of the spindle body are different from a ball join spindle
so what is the solution to have porsche pattern in front with late barkes drums??
is there enough material/steel to remove around the bearing housing of an early brakes drums  as this i can  machine  my 61 brakes drums and redrilled them to accept the porsche wheels??
thx for your advice friends
« Reply #1 on: September 18, 2020, 19:07:36 pm »
I know you said no to discs, but you can get a linkpin dropped spindle that has a later (4 lug) spindle. Then you just fit porsche pattern late model discs. Not hugely expensive and no more adjusting drums.....
« Reply #2 on: September 18, 2020, 19:38:43 pm »
lee no links ?? but i don't need to go lower too
i know i'm difficult  Grin Grin Grin
« Reply #3 on: September 18, 2020, 19:41:07 pm »
what do you think about those??
https://www.limebug.com/product/view/2316/front-disc-brake-kit-link-pin-5x130-91#temp
« Reply #4 on: September 18, 2020, 21:42:16 pm »
The kit you show in the link is exactly what I was referring to.
If you did run drop spindles assuming you have an adjustable beam you could wind that back up a bit to compensate. Probably make ride quality a bit better too.
« Reply #5 on: September 19, 2020, 09:39:00 am »
lee i don't have dropped spindle on my car , it's the original 61 spindle
the kit here don't have dropped spindle , ther's another kit with dropped spindle
https://www.limebug.com/product/view/2314/t1-1955-66-beetle-ghia-link-pin-front-premium-dropped-disk-brake-kit-5x130pcd-14mm-studs#temp
can explain me the difference between thos e2 kit
only the dropped spindle?
« Last Edit: September 19, 2020, 09:41:56 am by speedwell » Logged
« Reply #6 on: September 19, 2020, 15:37:47 pm »
IMO both kits use a dropped spindle so can't see the difference Huh
If you send Michael @ Machine 7 an email I'm sure he will look after you. He's great understanding what you are trying to do and suggesting what you new to buy.
« Reply #7 on: September 19, 2020, 16:31:22 pm »
thx lee
« Reply #8 on: September 19, 2020, 16:33:06 pm »
No problem. What wheels you fitting?
« Reply #9 on: September 19, 2020, 16:46:32 pm »
you will see next year  Grin Grin
i think one kit have dropped spindle and not the other one , in the description it's written dropped and not in the other one
have you  micheal emial adress??
llimebug is a serious shop?? just asking
« Reply #10 on: September 19, 2020, 17:16:40 pm »
sales@machine7.com has helped me with technical stuff a few times over the years.
Have dealt with Limebug a few times, always been super quick with delivery and emails
Look forward to seeing your car with its new wheels  Grin
