September 24, 2026, 21:53:50 pm
| |-+  For sale!
| | |-+  67 turbo bug.
Author Topic: 67 turbo bug.  (Read 4021 times)
Garrick Clark
« on: September 23, 2020, 16:07:21 pm »
Thinking of a change. So my 67 might be on sale.
Its a USA import 67 savanna beige bug, I have owned it near 10 years
All steel. Never welded, No Rot anywhere. Removable original valance, Patina style.
Original seats as it came from the states
Lowered ,but too low
D ring wheel
Front and rear towel rail bumpers
original 1/4 lights and glass
2" narrowed beam.
Drop spindles.
Front discs
Big master cylinder
New shocks all round
Brm copies. 145 x 205 tyres
28 rear torsion bars
KCR swing axle box
mid mount
solid mounts
Rear discs
Short shift.
Type 4 turbo motor. 1911
86a cam
Big valve heads 42 x 36
Balanced bottom end
ARP bolts
200mm conversion flywheel
CB Dual disc
Stage 2 P Plate
CSP Pulley and CSP dell linkage
CSP 40 mm specific manifolds
CSP type 4 upright cooling shrouds
Twin 40 drla carbs
DVDA distributor
External oil cooler and fan
Standard oil filter delete. Now type 1 full flow style
All case plugs drilled n tapped
Hybrid turbo.
Blow off valve
Fuel return to tank reg
Fuel cut off safety
pump  carburetor prime button
OMEX rev limiter with 2 step
1 off Turbo Thomas header
Single outlet resonator pipe
PLX .. AFR gauge
AEM direct port water injection
Recent battery
H.I.D  UK Headlights
States Plates
Price is £15k ono
Lancashire UK.
Genuine inquires only
« Last Edit: October 04, 2020, 16:15:41 pm by Garrick Clark » Logged
Air cooled Engine builder
Garrick Clark
« Reply #1 on: October 16, 2020, 12:08:23 pm »
Not for the faint hearted
Garrick Clark
« Reply #2 on: November 01, 2020, 14:27:55 pm »
Gunna take more pics when the rain stops, This bug has seen no rain on its under carriage since I've owned it, which is 10 years
Garrick Clark
« Reply #3 on: November 02, 2020, 14:12:50 pm »
Comes with lid and valance
« Last Edit: November 02, 2020, 14:14:25 pm by Garrick Clark » Logged
