November 02, 2026, 08:45:07 am
Latest Member: thunder_bac
| | |-+  94mm Autolinea case barrel fitment
Author Topic: 94mm Autolinea case barrel fitment  (Read 17232 times)
Mike Cott
« on: October 04, 2020, 17:36:42 pm »
Hi all, I’ve purchased a new case that’s already been opened up to94mm, problem I have is that the Mahle barrels don’t sit in all the way, anyone else had experience with this?
In the first pic you can see a slight line round the barrel, it fits in up to that point
« Reply #1 on: October 04, 2020, 18:43:26 pm »
Whoever machined the case didn't cut it deep enough...
Mike Cott
« Reply #2 on: October 04, 2020, 18:59:49 pm »
They’re cut plenty deep enough
Chip
« Reply #3 on: October 04, 2020, 19:18:41 pm »
Is that a step on the barrel itself?
Mike Cott
« Reply #4 on: October 04, 2020, 19:21:19 pm »
Yeh they do have a slight lip which I would of thought was normal
UltraOrange67-2443
« Reply #5 on: October 05, 2020, 17:32:00 pm »
My cylinders are very tight, i have to wiggle them a little  Grin
1967 1200 2920cc EFI
« Reply #6 on: October 05, 2020, 18:00:41 pm »
Looking at the pic, the initial opening of the case needs to be slightly larger to except the larger stepped portion of the cylinder.
The case has been step cut, you may find the second cut needs enlarging too
Mike Cott
« Reply #7 on: October 05, 2020, 19:20:19 pm »
It would be a lot easier to take a little off the barrel at the step rather than taking it to a machine shop to re cut the case surely!!
What are your thoughts on that guys?
« Reply #8 on: October 05, 2020, 21:14:08 pm »
There is always that way. Just would have to repeat if you ever replaced a barrel
Mike Cott
« Reply #9 on: October 06, 2020, 15:02:49 pm »
I reckon I’ll go with grinding the barrels down, easier for me to sort I think
« Reply #10 on: October 06, 2020, 16:19:43 pm »
Have you tried all the barrels in one hole or all of them?
Mike Cott
« Reply #11 on: October 06, 2020, 16:38:24 pm »
😂 I’ve tried them all with different barrels too 😉
« Reply #12 on: October 06, 2020, 18:06:53 pm »
I wondered if one spigot had been machined a little tight on the case.  Cheesy
