September 20, 2026, 02:03:14 am
352309 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  JPM Raptor IDA stacks
Author Topic: JPM Raptor IDA stacks  (Read 12976 times)
Karlos99
« on: January 09, 2021, 12:15:56 pm »
Morning all
I’m in need of some new Velocity stacks for my IDA’s, I’ve come across the JPM set for a little more money than the genuine Weber style. Who’s got them? Who likes them? who doesn’t? And most importantly are they worth the money. Engine is a 2110, FK10 cam, ultramag heads with berg 35/40 grooved vents
Many thanks
Karl
henk
« Reply #1 on: January 10, 2021, 13:12:47 pm »
I think it would be beter then to get everything from JPM.
So both the stacks and venturi's from JPM.
Henk!!!
PPRMicke
« Reply #2 on: January 10, 2021, 18:53:27 pm »
Morning all
Many thanks
Karl
with JPM stacks and venturi (jpm) they flow much better than GB Venturi (that's with them are 70s think and vilever in the 20s)
For info in IDA 51.5 with jpm venturi (44mm) and stacks, the limit is 285 hp
/// Micke
H67bug
« Reply #3 on: January 28, 2021, 20:33:51 pm »
I have them with JPM venturis.
Can’t tell you what performance difference they made though...
I had a lot of fuel stand off (fuel was all over the place above 2k rpm) and the rolling road team didn’t want to run the car so I fitted Weber ones instead to dial the car in.
Have subsequently fitted them back on but not tested them yet.
I did test the Wasp exhaust back to back and that made a huge difference V A1 with +18bhp. I wonder if this will help the fuel spray issue.
PPRMicke
« Reply #4 on: February 09, 2021, 10:28:34 am »
When calculating the length of your intake pulse (pulse 2 or 3) it was in stacks or above or at the venturi
Or did you just put them there
/// M
H67bug
« Reply #5 on: February 09, 2021, 11:02:43 am »
Hi
I used what JPM suggested from head to Venturi
