October 31, 2026, 19:15:11 pm
352334 Posts in 28962 Topics by 6930 Members
Latest Member: thunder_bac
| | |-+  New MeXXspeed mill V3
Pages: 1 2 3 [4] 5 6 7 Print
Author Topic: New MeXXspeed mill V3  (Read 156562 times)
Prowagen
« Reply #90 on: April 06, 2021, 17:02:38 pm »
This engine build and the technology you are putting into it is phenomenal! Like many others I am blown away!
A couple of questions from a real novice; but with the injectors so high is there not an high risk of fire outside of the cylinder? Also is machining what you do for a living?
Regards,
Rob.
MeXX
« Reply #91 on: April 07, 2021, 08:51:38 am »
Regards,
Rob.
Dear Rob...
No & No....
If there is a back fire it will exit the manifolds anyway doesn't matter where the fuel injectors are located.... as long as the engine keeps on running its not a big problem as the injected fuel mixed with the air will not keep on burning... as soon as the engine stops running there is no fuel anymore.... In my opinion it is more dangerous to have fuel filters that soak up the fuel spit back through reversion.... and might keep on burning......
Drag or Die
MeXX
« Reply #92 on: April 07, 2021, 09:23:01 am »
The V3.0 was basically the prototype based on the development of the V2.X series.... which was improved  spep by step together with one of the most experienced induction system designer... Darin Morgan....
« Last Edit: April 07, 2021, 13:44:43 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #93 on: April 07, 2021, 09:36:24 am »
Step by step.... port modifications did not only improve the CFM numbers... even more important was to see more and more even airspeed distribution across the CSA.... using a pitot tube....
« Last Edit: April 07, 2021, 10:06:01 am by MeXX » Logged
Drag or Die
MeXX
« Reply #94 on: April 08, 2021, 12:03:16 pm »
Using a wet flow bench is quite interesting.... but not very useful without experienced people how can interpret the results.... After according port modifications including removing the bespoke vane step by step theflow increased....from the low lift (3.8CFM) to high lift (27.7CFM) region....
To get the best over all performance.... we tried to get the best off the seat and low lift flow and than rework the bowl and increase the CSA slightly to get the high lift flow without sacrificing the low lift numbers.....
Check out the second pix to see the benefit for all the countless hours of labor on the bench....
To be honest I'm very proud to work together with one of the gear heads in head design...
And reaching this for me unbelievable numbers... giving me the opportunity to built an unlimited NA engine....
« Last Edit: April 09, 2021, 06:54:42 am by MeXX » Logged
Drag or Die
« Reply #95 on: April 08, 2021, 15:02:12 pm »
OK, I have a comment again: THANKS!!!
MeXX
« Reply #96 on: April 08, 2021, 19:55:24 pm »
As soon as the head development was finished.... it was up to design the manifolds with the throttle bodies....
The tuned manifold length was set to 300mm (form the valve seat to the lip of the velocity stack) with the possibility to be shortened up to 25mm to be able to tune it on the dyno for best over all performance...
as the port is 90mm and the stack was set to 80mm (80mm -25mm =65mm (shortest possible stack)) the manifold including the throttle body ended up with a length of 130mm...
which is quite short.... so the decision was done to angle the throttle plates about 12° (see 2nd pix) to get a nice radius and therefore a nice flowpath with airspeed acceleration from the lip of the stack to the valve seat...
without having the necessity of going from left to right side radius....
« Last Edit: April 09, 2021, 07:23:26 am by MeXX » Logged
Drag or Die
MeXX
« Reply #97 on: April 11, 2021, 07:02:17 am »
The first two pix show nicely the radius of the whole induction system that tightens up towards the valve seat
The downside of the angled throttle plates is the angle between the center line of the shafts....
The levelers are designed to compensate the twisting tue engagement... the nice side effect is the the twisting acts like the return spring... see pix 3 and 4....
« Last Edit: April 11, 2021, 07:19:27 am by MeXX » Logged
Drag or Die
MeXX
« Reply #98 on: April 11, 2021, 08:00:24 am »
Drag or Die
dannyboy
« Reply #99 on: April 11, 2021, 22:26:30 pm »
epic work on all levels  Shocked  Cool keep at it
8.77@156.8mph
O/FF 60
MeXX
« Reply #100 on: April 12, 2021, 12:28:12 pm »
Drag or Die
MeXX
« Reply #101 on: April 12, 2021, 12:33:24 pm »
Drag or Die
MeXX
« Reply #102 on: April 12, 2021, 12:36:19 pm »
Drag or Die
MeXX
« Reply #103 on: April 13, 2021, 10:41:09 am »
Drag or Die
MeXX
« Reply #104 on: April 13, 2021, 19:45:34 pm »
Drag or Die
Abadco2
« Reply #105 on: April 13, 2021, 20:29:45 pm »
MeXX,  I was at EBI in 2019 and was privileged to see in person and talk with you as you explained in detail just some of the ultra special one offs of this most advanced vehicle.
The two things that I have focused on is, 1. the butterfly throttle returns shown here and 2. the fact that you have not taken out and have support for the valve seats.  I think this is overlooked in today's off the shelf performance heads, IMO.
I look forward to more of your postings.
Art A.
MeXX
« Reply #106 on: April 13, 2021, 20:54:39 pm »
Art A.
Hey Art....
 great to hear from you... and thx for your words of honor.... I really appreciate that....
I didn't really get your 2. point.... about the valve seats.... ?.
MeXX
Drag or Die
MeXX
« Reply #107 on: April 14, 2021, 14:39:19 pm »
Here come some pix of the super tricky throttle stops made out of billet TiA6V4.....
Drag or Die
MeXX
« Reply #108 on: April 14, 2021, 14:43:23 pm »
The machining to fit the throttle stops was done by hand by some quite tricky self made tooling....
Drag or Die
Abadco2
« Reply #109 on: April 14, 2021, 19:34:57 pm »
My valve guide point, is the after market guys cut away so much of the head material that supports the intake valve guide, subject to failure.
Art A.
MeXX
« Reply #110 on: April 14, 2021, 20:04:36 pm »
Art A.
Dear Art...
absolutely...
It us not only having enough support for the valve guide... it is the combination of quite long valves (5.480") to get a gentle radius....in quite long valve guides (2.650") for a precise support.... and a rigid support in the head....
This is one of the backbone of a stable valve train....
MeXX
« Last Edit: April 14, 2021, 20:07:32 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #111 on: April 14, 2021, 21:28:21 pm »
Drag or Die
mikko k
« Reply #112 on: April 17, 2021, 11:02:54 am »
This is so nice engine!!
How about my previous question?
Hi,
If it’s not secret, I’d like to ask that, how much is the cylinder pressure when you spin the engine by starter?
MeXX
« Reply #113 on: April 17, 2021, 11:31:35 am »
Hi,
Sorry bout that....
I was using a Motormeter pressure tester for decades.... but the measurements highly depends on the battery and the starter.... doing testing you can clearly checkout a drop of measurement from test to test..... which makes it quite hard to get a accurate feedback.... but anyway.... better than nothing.... what I did....  I tested cylinder 1 2 3 4... waiting a little bit giving the battery and the starter the chance to recover.... then cylinder 4 3 2 1.....
But my new engine excited the measurable value of 12bar... and the diesel version is able to measure up to 40bar.... would be quite inaccurate.... so I changed to aviation style leak down tester....
Hope this answers your question.. at least partly.....
MeXX
« Last Edit: April 17, 2021, 11:52:52 am by MeXX » Logged
Drag or Die
mikko k
« Reply #114 on: April 17, 2021, 12:11:37 pm »
Thanks Mexx.
I have the same Motormeter tester. And its a bit tricky to use. So I have it and just normal pressure gauge to read while someother person starting the engine. And leak tester also.
Ofcourse pressure will be different depending on battery and starter.
Thanks for your answer!
« Reply #115 on: April 17, 2021, 19:13:59 pm »
Good work - I wish I had a little of that time ...  see you  Smiley
Griebel
« Reply #116 on: April 17, 2021, 20:24:46 pm »
 Shocked Cool
« Last Edit: April 17, 2021, 20:28:12 pm by Griebel » Logged
Instagram: c.griebel
       "BEYOND 4 INCHES"
          MIB,DENMARK
MeXX
« Reply #117 on: April 19, 2021, 06:48:33 am »
Found a really nice pix of the "flow path" of the intake port with the manifold as it was designed....
still with the vane on the short side radius... which was removed later on in the R&D...
check out the rigid support of the valve guide Art Alvarez was talking about....
« Last Edit: April 20, 2021, 11:04:46 am by MeXX » Logged
Drag or Die
brewsy
« Reply #118 on: April 20, 2021, 20:49:51 pm »
Flow path?
Come on MeXX those things are more like DRAINS than ports!!
In 'English' we have an expression about it 'not touching the sides'  Grin Cheesy Wink
MeXX
« Reply #119 on: April 21, 2021, 05:57:28 am »
Flow path?
looks like size does matter....
Drag or Die
