September 21, 2026, 17:44:53 pm
| | |-+  Piston Weight Matching
Author Topic: Piston Weight Matching  (Read 21639 times)
brewsy
« on: March 14, 2021, 19:38:31 pm »
Hi All,
As you all know with our hobby there is no thing as a simple fix.
My engine is a stock SP1300 and has developed an exhaust leak/blow so needs changing.
That's currently on backorder as there seem to be none in the UK so I decided that I may as well pull the motor to make it easier to fit the new exhaust (thats my excuse) and then whilst Im there I'll do small 'stock ish' performance upgrade. No cam changes, no new valves (unless they are toast and certainly no larger), no rocker arms and stock (ish) heads, carburettor and rev limit.
  • Swap B+P's to 1600
  • Install the slightly odd 4 dowel pin 12lb lightened flywheel that I own
  • Check and carbon clean the preheater tube on the manifold
  • DIY port the SP heads
  • Install and re-jet a slightly bigger Solex carb
  • Install a Mexican style oil pump with spin on filter
As Im not splitting the cases Ive decided to try and do all this myself and using second hand parts to keep the costs as low as possible.
First purchase was some eBay 1600 B+P's which turned out not to be 85.5mm but first oversize at 86mm and with 2x of them having the pin retaining grooves worn out  Roll Eyes
I managed to source 2x more 86's with good grooves however it turned out I now have 2x KolbenShmit and 2x Mahle pistons. Didnt think that this would be as issues as they are both OEM suppliers (I think?) and should therefore be pretty well matched.
Turns out I was wrong as after a good degrease and clean the weights seem waaayyyy off:
2x are 422g
2x are 407g
Ive had a look at 'how to match piston weight' etc all over the web and does seem a normal thing to do however most people usually only need to take 1-2g maximum out of their pistons as they are starting with a matched set.
Questions:
What's the safest stock mismatch anyone has seen? Are there specs from VW?
Can I safely take 15g from a stock cast piston?
If I cant take that much from the piston how much could I take could I then find the rest in the piston(gudgeon) pin?
I probably should have just bought some new 85.5 or 87mm pistons and be done but Im too stubborn at this point and want to try (as hard as possible) to make it work.
Besides which I like the fact that the 86mm pistons give EXACTLY 1600cc!!  Cool
Marc
Martin S.
« Reply #1 on: March 15, 2021, 03:51:35 am »
Take the weight off the pins. You can use a drill that is just over the inside diameter.
Take the valves out and check the guides fit. Then you can hand grind the seats if you have the tool and get new stainless valves, get someone to grind them, or at the very least hand lap them.
brewsy
« Reply #2 on: March 15, 2021, 20:08:15 pm »
Thanks Martin
« Reply #3 on: March 16, 2021, 09:05:56 am »
A solid carbide drill big enough is going to cost over a hundred $.
alex d
« Reply #4 on: March 16, 2021, 09:23:53 am »
I would just run one pair on 1-3 and the other on 2-4
Jesse Wens
« Reply #5 on: March 16, 2021, 11:31:28 am »
this is exactly what I was thinking too. Just match the opposing pistons and call it a day for your level of performance.
Martin S.
« Reply #6 on: March 16, 2021, 14:12:41 pm »
How much with a 5-finger discount Bruce?  Cheesy
brewsy
« Reply #7 on: March 17, 2021, 15:12:49 pm »
Cheers Alex.
That had crossed my mind too.
Didnt want to say anything first as I didnt want to miss any potential ideas..  Cheesy
May still see if I can get some aluminium from under the crown AND dremel the pins.
Would like weights to be somewhat close so as to keep the rocking couple down to a minimum.
Now the question is...
Heavier pair on 1+3 OR 2+4  Grin
Im thinking 1+3 so as to keep the rocking closer to the centre of the car but arent there more bearings at the 2+4 end?
Or am I just overthinking that??
Marc
mikko k
« Reply #8 on: March 17, 2021, 17:57:27 pm »
Factory info is max 5g weight difference between pistons. I would go max 1g diffrence.
15g is a lot! I wouldn’t even start to balance these.
But everybody do what they want to do.
brewsy
« Reply #9 on: March 20, 2021, 17:49:08 pm »
Here's some pictures.
KS vs Mahle
Underside Mahle
Underside KS
Looks like way more 'meat' on the KS....
Headed to the garage and it seems that my two scrap pistons are KS.
Got the daughter to help and a few minutes later we had...
brewsy
« Reply #10 on: March 20, 2021, 18:14:35 pm »
And then measured at some spots
[ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
So compared to the Mahle there is much more meat (obviously) and even if I remove all the 'ribbing' the crown still looks to be about 8mm of ally.
Been on eBay and ordered one of those corded drill to pillar drill things, £15 well spent I reckon!!
Will drill the F out of them and I might actually get within the 5g VW difference Grin Cheesy
Martin S.
« Reply #11 on: March 21, 2021, 00:29:40 am »
Interesting to see the cross-section, thanks!
The crown of the piston is most crucial when it comes to strength which is a factor in dishing pistons.
That’s likely the reason pros balance using the pins not the pistons.
Another reason is that pistons also have a inherent balance to them across the pin axis to keep the “snap” force to a minimum.
And also keep in mind that aluminum is half the mass of steel so you would need to remove twice as much.
None of this would matter with a STF engine so no big deal.  Cool
PPRMicke
« Reply #12 on: March 21, 2021, 10:38:49 am »
info Vw had a limit of 5 grams on a std engine Replacement piston was 10 grams but I would never dare to put in 10 grams I want to be closer to 1 gram both on piston and rod (the smaller the difference the better) It will be ( tonnes) in force when there is a weight difference
We who play with the 1600 challenge in Sweden use Mitsubishi which is 86 mm (85.95) o piston pin of 22mm But if you think the effect is in the piston should probably think once to Na the engines are around 130-168 hp and turbo around 300 hp
/// M
brewsy
« Reply #13 on: March 21, 2021, 14:28:57 pm »
Cheers Martin,
One question.. What does STF stand for??  Huh
Marc
brewsy
« Reply #14 on: March 21, 2021, 15:05:07 pm »
/// M
Micke,
Thanks for that but this if this build hits 55-60BHP at the flywheel Ill be happy!
Im staying with stock manifold, carb and exhaust so RPM range will be pretty much stock
Martin S.
« Reply #15 on: March 21, 2021, 16:20:12 pm »
Sweep The Floor. Using parts leftover or on hand like what you’re doing.
brewsy
« Reply #16 on: March 21, 2021, 19:50:18 pm »
AHA.
Like it  Cheesy Wink
« Reply #17 on: March 25, 2021, 23:40:59 pm »
Jim Ratto was the first one I heard using that phrase, about 25 years ago now! He'd got some great stories about STF motors!
Rome
« Reply #18 on: April 19, 2021, 18:47:12 pm »
Check the first 3 digits of the part number on your 1300 heads. If it's a "113", then those heads' combustion chambers will need to be machined to a larger diameter to accept your bigger cylinders. Also realize that the valve sizes on 113 heads are smaller than the SP heads that were on the 1500 & 1600 engines: 33 x 30 mm vs 35.5 x 32 mm. So if you keep the 1300 heads, you will see a power increase because of displacement, but the "full" power potential will be held back compared to finding a good set of 1500 heads (P/N starts with 311, or 040 for Brazilian replacements). If you can find a pair of the 311 SP heads, they will not need to be bored for the 86 mm cylinders because that was the first oversize for a straight swap with the originals. Replace your exhaust valves in any case, and try to find a local machine shop that can do a 3-angle valve job.
If you use your 1300 intake manifold, also realize that it has a slightly thicker main pipe so that the inside diameter is slightly smaller than a manifold for the 1500/1600 SP engines. You can see this by the wider shoulder/ledge in the 1300 head where you place the copper sealing gasket. If you find a 1500/1600 manifold and keep the 1300 heads, you can mark the exposed ledge on the inner diameter of the copper gasket, and grind it away using a carbide burr in a drill. If you find some 1500/1600 SP heads and manifold, carefully pry out your 1300's copper gasket, place it in the other head, and also mark the ledge so you can see how much head material you can grind away so that the gasket still sits fully on the ledge.
Piston pins: That's dang hard metal. Years ago I tried to use a cone-shaped "stone" in a drill, and the pin was untouched like Superman. The stone fell apart. BMW's Motorsport engines use pins that have a tapered center hole, with the outer edge being about half the thickness of the center. The taper goes in about a centimeter.
brewsy
« Reply #19 on: April 20, 2021, 20:46:49 pm »
Thanks Rome.
All good information
