November 04, 2026, 01:54:30 am
| | |-+  Stealth67, what have you noticed from the changes?
Author Topic: Stealth67, what have you noticed from the changes?  (Read 4752 times)
The Ideaman
« on: November 17, 2007, 18:00:25 pm »
1776
DMS crank
Rimco 13 lb flywheel
Berg 6.5 lb power pulley
Engle W125 w/magnum gears
8.9 CR
Bosch 010
stock valve ported heads dual springs, ti retainers
1 1/2 header dual qps
44 IDFs 36 vents 125 mains
30 weight Kendal
28 mpg highway over 40,000 miles
18-20 mpg in town or traffic
Same engine with
VW 1.25 rockers
9.3 CR
welded, ported CB 044s 40 x 35.5 ti retainers
Berg/Stinger S4 ignition
1 5/8 w/ dual qps or 2 1/2 Magnaflo
48 IDAs w/37 vents 135 mains
25-26 mpg highway for 20,000 miles
14-16 mpg in town or traffic
10 or less with my foot in it.
From the other forum.  Thinking of building something similar for my brother in AZ.
It is the soldier,
Who salutes the flag,
Who serves beneath the flag,
stealth67vw
« Reply #1 on: November 18, 2007, 16:01:44 pm »
With the stock ported heads and 44 IDFs the engine transitioned off idle a lot smoother. With the 044s and IDAs there was a stumble around 1800-2200 rpm that we could not tune out of it. Jim Ratto, Jerry Young (owner of Buggy House) and myself could not get rid of it so I just got used to it since I mostly drove it on the freeway. The powerband was moved up compared to the IDF configuration but still very drivable. If did it over again, which I plan too it will use 94s and I will sleeve the lifter bores. Wobbled lifter bores was the reason I tore it down, oh and to install a 78.4 crank.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
