April 10, 2026, 12:21:02 pm
352104 Posts in 28882 Topics by 6917 Members
Latest Member: joni75
| | |-+  14" Fuchs
Author Topic: 14" Fuchs  (Read 21300 times)
CrossFit_Pete
« on: August 30, 2021, 21:56:36 pm »
Has anyone fitted a set of 14" Fuchs to a Cal Look bug? Are they really too small or is it the tyres that are the problem?
« Last Edit: August 30, 2021, 22:40:20 pm by CrossFit_Pete » Logged
Larry S
« Reply #1 on: September 15, 2021, 22:13:07 pm »
This was my 57 back in 1982-83 with 14" alloys
CrossFit_Pete
« Reply #2 on: September 15, 2021, 22:20:19 pm »
Thanks Larry, looks great
Larry S
« Reply #3 on: September 15, 2021, 22:33:35 pm »
you are welcome, I never had any issues and they worked great. I had a 1750cc (69x90) huge welded heads and IDA's on it along with close trans. 4:12 R&P and a 1;21 4th. high RPM motor, with the shorter tires it didn't bother it. It ran pretty well, didn't lose to many street races with it. They were Michelin tires on them.
CrossFit_Pete
« Reply #4 on: September 17, 2021, 12:06:49 pm »
I have dropped spindles on the front of mine, not sure they will fit otherwise I'd get a set.
Steve67
« Reply #5 on: September 19, 2021, 07:26:25 am »
Which Front beam do you have? 66 and later will most likely be an issue.
I even had to modify my dropped spindels for Ronal 15 inch wheels
CrossFit_Pete
« Reply #6 on: September 19, 2021, 20:39:33 pm »
Car is '67 2" narrowed beam with dropped spindles.
stealth67vw
« Reply #7 on: September 19, 2021, 21:58:29 pm »
I run 15 x 6s with dropped spindles and they hit the inside of the wheel hoop. No way you could run 14s with dropped spindles.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
« Reply #8 on: September 21, 2021, 12:13:07 pm »
CB dropped spindles? They are not machined deep enough for the bottom ball joint to sit in, hence they foul/rub the wheel rim
« Last Edit: September 21, 2021, 15:14:11 pm by leec » Logged
stealth67vw
« Reply #9 on: September 21, 2021, 19:21:10 pm »
Empi and CB both rubbed on the lower ball joint.
« Last Edit: September 23, 2021, 20:43:03 pm by stealth67vw » Logged
John Bates
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
Larry S
« Reply #10 on: September 21, 2021, 22:02:14 pm »
I ran stock spindles, disc brakes on link pin front end, was lowered via adjusters. didn't have any issues with clearance on both 14" and 15" alloys.
56BLITZ
« Reply #11 on: September 22, 2021, 05:36:53 am »
This is my 1970 . . . stock width beam . . . stock spindles . . . 14X5.5 alloys in the front and 15X6 alloys in the rear.
I recently put 14X5.5 alloys on the rear w/215-70 tires and it now looks much better than with the puny 165s in these photos!
FWIW . . . my son's 1969 with Empi dropped spindles rubbed on OG 15X5.5 Riviera wheels, so . . . the dropped spindles had to go away!
« Last Edit: September 22, 2021, 05:59:12 am by 56BLITZ » Logged
CrossFit_Pete
« Reply #12 on: September 24, 2021, 20:02:07 pm »
I'm running genuine gas burners with no issues at present.
67paulo
« Reply #13 on: September 25, 2021, 04:26:03 am »
I'm running 15x6 original Fuchs, CB 2 inch narrowed beam, CB dropped spindles on my 67 and have no rubbing issues.
Steve67
« Reply #14 on: September 25, 2021, 07:08:48 am »
Hey Paulo,
Do you have an picture is your 67 with the 6 inch Fuchs in the front?
A friend is planning the same setup for his 67.
Best regards Stefan
« Reply #15 on: September 25, 2021, 07:26:33 am »
Nice wheels. Are you planning to take these off to run the 14” Fuchs?
CrossFit_Pete
« Reply #16 on: September 25, 2021, 11:10:29 am »
Probably keep them for a while, will probably get 15" Fuchs to be honest but would have been happy with 14" if they fitted, they are a lot cheaper!  Smiley
« Last Edit: September 25, 2021, 19:19:31 pm by CrossFit_Pete » Logged
« Reply #17 on: September 25, 2021, 11:46:17 am »
Yes, although the 14” ones seem to be getting more expensive.
Have you got a pic of your car with the Burners?
CrossFit_Pete
« Reply #18 on: September 25, 2021, 12:28:35 pm »
Steve67
« Reply #19 on: September 25, 2021, 16:46:31 pm »
Looks great on the Gasburners!
CrossFit_Pete
« Reply #20 on: September 25, 2021, 19:20:35 pm »
Thank you! I think they're underrated.
Baz54
« Reply #21 on: September 25, 2021, 20:39:24 pm »
Hi,Here’s mine on 14”s. Very similar to  Larry S . I think it suits the car,no drop spindles but an adjustable beam.
Baz54
« Reply #22 on: September 25, 2021, 20:44:40 pm »
I’ll try again , hopefully it’s not upside down  Cheesy
CrossFit_Pete
« Reply #23 on: September 27, 2021, 21:42:10 pm »
Very nice  Cool
Baz54
« Reply #24 on: October 04, 2021, 21:02:20 pm »
Cheers  Smiley
