September 22, 2026, 07:36:16 am
| | |-+  Change of cam in engine with Schubeck lifters
Author Topic: Change of cam in engine with Schubeck lifters  (Read 13816 times)
Speed-demon
« on: November 18, 2007, 23:07:53 pm »
I am considering to change my can drom FK 10 to FK 87 or FK 89. My engine currently runs with Schubeck ceramic lifters. Do I need a new (extremely expensive) set of lifters with the new cam, or can I run the lifters I already have?
I have heard that the Schubeck lifters do not need to break in, which tells me that I can use my old lifters with a new cam.
Does anyone know??
Thanks in advance.
Jens
Norway
« Reply #1 on: November 18, 2007, 23:47:48 pm »
Does anyone know??
Thanks in advance.
Jens
Norway
No thats what you payed that money for,just put the new cam in and your good to go Smiley
cheers richie,uk
« Reply #2 on: November 18, 2007, 23:49:05 pm »
I'll trade you for some new Scat Lube-Your-Hole's.  Grin
Everything I've read suggests you can reuse Shubecks on any cam you choose over and over. They never wear out.
Speed-demon
« Reply #3 on: November 19, 2007, 10:46:21 am »
No thanks I have tried them Scat lifters, and they pitted.... So I'll stay with the Schubecks.  Grin
Any special advise in running ceramic lifters? Thall I use "break in" grease with the Schubecks and the new cam?
BR
Jens
« Reply #4 on: November 19, 2007, 12:39:30 pm »
You dont have to bed them in either,unlike a normal Cam/lifter break in with Shubecks you just fire it up and are good to go Smiley
cheers richie,uk
Speed-demon
« Reply #5 on: November 19, 2007, 13:25:20 pm »
cheers richie,uk
so no grease? OK!
« Reply #6 on: November 19, 2007, 16:48:16 pm »
cheers richie,uk
so no grease? OK!
if you are just changing cams then a little lube to help till it gets oil pressure,but it should be imersed in oil, if the level in the motor is correct.
cheers richie,uk
Alan Uyeno
« Reply #7 on: November 23, 2007, 08:29:14 am »
cheers richie,uk
so no grease? OK!
I'd use moly disulphide (arp lubricant you get with arp bolts) It just sticks on the lifter better. You shouldn't worry about the schubeks. I just hope you have silicon/bronze lifter bores.
Speed-demon
« Reply #8 on: November 23, 2007, 10:34:34 am »
I do not know whether or not I have silicon/bronxe lifter bores. The engine is built by Udo Becker, so I better contct him to find out. Why do I need such lifter bores with ceramic lifters (out of curiosity)Huh
Jens
Norway
« Reply #9 on: November 23, 2007, 10:52:38 am »
Jens
Norway
Because of wear. In mag cases there has been cases where the bores was oval after very few miles. I did not know that the ceramic lifters was more agressive against the bores than other lifters and thought this had more to do with cam profiles and pressure.
Alan - you had a bad experience with the FK47 in a mag case if I`m not mistaken? Please share your experience with us if you feel like it. Personally I`m interested in knowing if this is likely to happen with alu cases as well.
Best rgs
BB
Jordy/DVK
« Reply #10 on: November 23, 2007, 13:26:06 pm »
 Are those Ceramic lifters any good? I mean, if they break (or rather shatter) those tiny ceramic grains get dragged along with the oilflow scratching every singe part in the engine.
 Great things, but I wouldn't want to experience a failure of one of those...  Embarrassed
 (then again if a rodbolt fails it could do serious damage as well)
  "The Full-Throttle Cruisers"
Alan Uyeno
« Reply #11 on: November 23, 2007, 17:23:52 pm »
Jens
Norway
Best rgs
BB
Must we bring up bad experiences  Cheesy Cheesy Cheesy
I highly suggest silicon/bronze sleeves due to lubricating properties of the material. The sideload of a rampy fk40 series cam with stiff valve spring pressure is a very potential chance of lifter bore wobble. With a ceramic lifter your in real deep poop!!! My udo becker tool steels took a serious beating and I reused the lifter for an fk46 in a different case (sleeved). Mind you I'm using a mag case not an aluminum t1 case.
Aluminum is still not as good as silicon bronze. For example Rimco will sleeve a mag case with aluminum. IMO why spend money on aluminum sleeves when you can use a far superior material like silicon/bronze.
If I had an aluminum case I would use it till it needs sleeves. BUT in a mag case I will NOT EVER use a fresh virgin mag case without sleeving it. I've been bitten twice with severely wobbled lifter bores and getting caught with your pants down twice is simply stupid in my part.
I think Udo mentioned to me that he always uses sleeved cases.
« Reply #12 on: November 25, 2007, 22:13:38 pm »
Jens
Norway
I think your case has no lifter bushings . What engine do you have ? I never used ceramic lifters
udo
« Last Edit: November 25, 2007, 22:15:19 pm by Udo » Logged
