October 28, 2026, 16:37:37 pm
Hanibal1
I'm back after 30 years in a 1969 KG coupe
Topic: I'm back after 30 years in a 1969 KG coupe (Read 36601 times)
Joe Hullett
Re: I'm back after 30 years in a 1969 KG coupe
Reply #30 on:
December 20, 2021, 23:32:40 pm »
The bump stops are under the top sleeve of the front shocks leec. Cut the welds at the top of the sleeve and remove it, you will find the bump stops underneath the sleeve. I cut over an inch out of mine that gave me some extra travel although I may be at the limit of my ball joint travel now. The EMPI extended travel ball joints are on their way from CIP1.
The older I get... The faster I was... No Fear
