October 05, 2026, 13:00:27 pm
Latest Member: Chakalives
| | |-+  Door Hinges Pip Pin quick release
Author Topic: Door Hinges Pip Pin quick release  (Read 12842 times)
samotorsport
« on: November 24, 2021, 16:01:53 pm »
Hey gents , i plan in putting a quick release system into the door hinges of my dragster.
The original pins are conic , so a M8 x 65 falls straight through and does not guide the door very precise.
I wonder what you did , bushing into it and reamed to 8 mm ? Or any other kind of pin or bolt used ?
Please share your experience and maybe some pics and a place to order the pins .
Thanks in advance
Sam
« Reply #1 on: November 25, 2021, 15:47:33 pm »
Good topic!  I am close to doing this to my CF doors installment.
Would be nice to get some idea inspirational pictures.
ottobros
« Reply #2 on: December 01, 2021, 09:44:41 am »
hi
you can use a quick release pin size 21/64 = 8,33 mm or the 11/32 = 8,73 mm best way to do
regards Otto Bros 😎
samotorsport
« Reply #3 on: December 01, 2021, 10:02:35 am »
Thanks a lot ! Where did you get yours from ?
« Reply #4 on: December 01, 2021, 10:40:26 am »
Here's what I did on my cars: cut the stock lower hinge but leave the stock hinge pin in place. You can then slide the door onto this pin and then simply use a pit pin (quick release pin) on the top hinge. It makes it very easy to refit the door by yourself...
« Reply #5 on: December 01, 2021, 13:25:26 pm »
Good one! Thanks!
samotorsport
« Reply #6 on: December 02, 2021, 20:45:07 pm »
Thanks a lot .
So here is what I did . Not the quickest way but very precise , and quick enough for my needs .
Upper and middle part drilled to 10 mm, lower hinge tapped to M10 .
So you slide the door in place , keep it there with the bolts in and lock it by screwing it down .
For the moment standard allen key M10x60 installed .
Gonna swap them to dome head bolts on final assembly
