October 12, 2026, 22:56:02 pm
| | |-+  Motometer gauge senders
Author Topic: Motometer gauge senders  (Read 8167 times)
nlvtinman
« on: December 02, 2021, 21:26:10 pm »
Like most, you can find the gauge cluster, but the senders are gone. Has anyone found a working alternative to be able to use this Motometer unit?[
« Reply #1 on: January 01, 2022, 21:20:57 pm »
Do new VDO or Autometer ones work? Or is it a case of taking the guts out and rebuilding them with other innards?
« Reply #2 on: January 30, 2022, 19:13:21 pm »
Perhaps you could check with a place like Hollywood Speedometer or another gauge expert? They could likely test and measure the signal needed and suggest a supplier.
I've done the same with the new fuel gauges for late cars as it's getting harder and harder to find good originals.
Good Luck with it, Nvltiman  Wink
