September 23, 2026, 10:25:57 am
| |-+  For sale!
| | |-+  Blue Carbon circuit racer
Author Topic: Blue Carbon circuit racer  (Read 2262 times)
« on: March 16, 2022, 16:00:07 pm »
1975 Blue Carbon track racing for sale
Complete car, rolling chassis or just gearbox with axles.
Golf front suspension coilover
Urethane bushings
Koni damper front and rear.
Adjustable ssupension arms at the back.
Brembo 4 piston calipers at front with ventilated discs.
Double Blue top fule pumps pulling through GB Oberg prefilter from the tank.
OMP Aramid-Kevlar fiber seat "for small narrow asses".
Full cage. Mostly bolted to the car apart from front suspension towers.
Aluminum front suspension crossbar.
Gene Berg  gear shifter
KCR 6 rib 002/091 hybrid gearbox. GB600 front gear housing with all Weddle gear, new bearings and full rebuild and Peloquin ATB diff. 930 CV with 28 splines 300M steel shafts that are gun drilled.
Slotted and drilled discs in the rear with CB conversion and handbrake.
BMW 17" rims and all-new R tires. Never used Nankang A2R  235/40/ZR17" and 205/40/ZR17"
The car can be driven but the engine is a mild TIV 2.1 cc of about 120-130 hp.
Dry sump tank in the right back seat.
Oil cooler with electric fan left rear seat.
Carbon fiber fenders all around, bumper front and rear, hood and hatch, running boards and rear lower cover under the hatch. Carbon fiber Remmele doors are available but are not mounted and sold separately. Carbon fiber rear-view mirrors.
Carbon fiber wing with tall support.
Rolling chassis 65000kr or €6200
Gearbox with 930 CV´s and gun drilled axles 300M 50000kr €4750
2.1 TIV engine that is exclusively built for turbo but is currently running with 2pcs Weber 51mm carburetor, 45000kr €4750
Send me an e-mail and I will share a lot of detailed pictures. fredrik@reichel.nu
Located in south of Sweden.
Fredrik +46 707989285
« Last Edit: March 16, 2022, 16:04:38 pm by Frallan » Logged
