September 21, 2026, 17:45:38 pm
| | |-+  Centerline Wheel nut fitting help
Author Topic: Centerline Wheel nut fitting help  (Read 4772 times)
Jimbosmith
« on: May 01, 2022, 18:15:14 pm »
Hi everyone,
Having some technical issue with mounting my centrelines to a late beetle 1970.
They are original split rims, with a 17.27mm 0.68" bolt hole.  Now the only lug nuts to fit a m14x1.5 press in stud i can find are a 19.05mm 0.75 fitment.  So do i need to have the wheels redrilled to use the lug nuts or am i best just fitting a m12x1.5 stud?
Currently i just have standard m14x1.5 wheel bolts but id like press in studs and nuts and the car will see track use so dont fancy the conversion stuff.
