September 21, 2026, 19:50:05 pm
Technical stuff
Turbo oil return
Topic: Turbo oil return (Read 9681 times)
chez2165
Turbo oil return
May 09, 2022, 12:03:11 pm »
I have a bus that's running a single throttle body that's turboed. The previous owner has plumbed the oil return out of the turbo through an independent pump and back into the block off plate of a universal case.
I'm wanting to simplify things and remove the pump, I have a deep sump that has an oil fitting within, what I'm wondering is if there would be enough pressure out of the turbo to return the oil into the deep sump.
Any advice is gratefully received.
Re: Turbo oil return
May 09, 2022, 12:23:35 pm »
Where is the turbo located?
chez2165
May 09, 2022, 13:07:59 pm »
I have attached a couple of photos
chez2165
May 09, 2022, 13:09:26 pm »
And another.
spoolin70
May 09, 2022, 15:10:53 pm »
Is the turbo mounted above the level of the fitting in the sump ?
Or in other words, would there be a drop/fall on the return pipe ?
chez2165
May 09, 2022, 15:48:03 pm »
There is definitely a fall of approximately 2 to 3 inch I would say but I haven't fitted the sump with the oil return yet but going on the position of the current sump extension I would say so.
May 09, 2022, 18:02:27 pm »
As long as it can drain down with gravity it will work fine, keep drain hose size as big as possible AN-10 at least is my choice
chez2165
May 09, 2022, 18:07:56 pm »
Thanks for that it's appreciated.
