October 13, 2026, 22:33:51 pm
2276 efi engine
Topic: 2276 efi engine (Read 4513 times)
baz
2276 efi engine
May 26, 2022, 14:21:28 pm »
Selling my 2276 efi engine. Full turn key. Approx 9k miles. Heads just been refurbed.
Dpr crank and flywheel
Cb h beams 5.4
Mahle forged pistons miles old
Grant rings 50 miles old
AA thick wall cylinders 50 miles old
Raptor 008
TP lightweight tool steel lifters
Dual tapered aluminium Logmech push rods
Titanium retainers
New springs
Jeff Denham / torben alstrup 041 heads. Just redone by torben, 44mm and 37.5mm valves
Scat 1.4 and 1.25 rockers on exhausts
Gene berg 26mm pump
Gene berg 3.5 quart sump
Vw speedshop efi 45 kit, manifolds fully match ported by torben.
Vw speedshop 1 5/8 hideaway exhaust
Dtas40 ecu with full custom loom
Customised fuel tank with phantom stealth internal fuel pump system
Oil pressure and temp gauges, innovate afr gauge, rev counter all included including wiring
All tinware including scat dog house fan shroud with thermostat flaps and linkage and thermostat.
Full flow oil lines and filter head
Fuel regulator and lines
Brand new kennedy stage 2 daiken disc
Basically full turn key package, just add fuel lines to your chassis.
€6500. Can be seen running. Located near Dublin Ireland. Can ship on pallet.
Last Edit: May 26, 2022, 14:33:12 pm by baz
I will prevail.
baz
Re: 2276 efi engine
June 04, 2022, 15:46:25 pm »
Package deal available, 1969 us spec chassis, original floor pans, irs rear, adjustable beam, porsche pattern discs with studs, rear drums with studs, koni shocks all round, sway away spring plates, sway away 26mm short torsion bars, original mahle magnesium gas burners. Dual stainless Steel fuel lines through tunnel. Mid mount. All brakes, master cylinder, ball joints, tie rods etc like new. Chassis was blasted and epoxy painted 3 years ago.
Basically full rolling chassis and engine, less gearbox. Slap your body on top and ready to go. €10k
I'm putting my bug back to stock and back on original pan and running gear.
Last Edit: June 04, 2022, 15:47:56 pm by baz
I will prevail.
Re: 2276 efi engine
June 08, 2022, 09:17:51 am »
Sounds like a very nice deal! I think you should/will sell that promptly.
Some of my cars:
chez2165
Re: 2276 efi engine
June 16, 2022, 00:00:20 am »
Nice motor, just a query on the Speedshop exhaust. What's the fitment like, can you still run tinware with the exhaust.
baz
Re: 2276 efi engine
June 21, 2022, 20:05:27 pm »
Quote from: chez2165 on June 16, 2022, 00:00:20 am
Yeah lower tins need notching but otherwise it fits
I will prevail.
