October 28, 2026, 16:36:27 pm
352330 Posts in 28962 Topics by 6929 Members
Latest Member: Hanibal1
| | |-+  Jo's 1956 barn find
Author Topic: Jo's 1956 barn find  (Read 18306 times)
swakke
« on: August 26, 2022, 20:32:50 pm »
Hello everyone,
I wanted to share my car with you all...
It's a 1956 VW oval that I found in a barn after standing there for a lot of years.
It's been 10 years in the making, and for the last 2 years I could drive it.
Until now... it needs some upgrades on engine, suspension and gearbox.  Wink Wink
The engine is an 1776 cc, the output is 115 hp and 160 Nm.
I'll keep you all updated!!
« Last Edit: August 26, 2022, 20:46:06 pm by swakke » Logged
VWGlassee
« Reply #1 on: August 26, 2022, 22:43:13 pm »
Welkom Swakke  Cool
swakke
« Reply #2 on: August 27, 2022, 09:51:41 am »
Hey Yannick, thanks!!
I'm working on the gearbox for the moment... trying to make some improvements.
It's an AS version with the longer ring and pinion, that must be converted from IRS to swing axles.
Placing a stronger differential with 4 spider gears, steel shift forks and hardened keys, and stronger side covers.
For me, I can understand the improvements everyone is doing .. except from welding the synchro hubs...
But we will figure it out.. it's the first time I'm going to do this. But we never give up!!  Cheesy Cheesy Cheesy
For the moment it's lying on my workbench like this..
« Last Edit: August 27, 2022, 11:56:12 am by swakke » Logged
mikko k
« Reply #3 on: August 27, 2022, 17:20:46 pm »
When you have power enought, you will understand..
swakke
« Reply #4 on: August 28, 2022, 00:19:40 am »
 Cheesy Cheesy Cheesy good quote!!
« Last Edit: August 30, 2022, 18:17:57 pm by swakke » Logged
swakke
« Reply #5 on: August 30, 2022, 18:18:18 pm »
Does anyone know where I can order steel shift forks and hardened keys separately?
Thnx!
mikko k
« Reply #6 on: August 30, 2022, 19:35:27 pm »
If you have that 1776cc engine with 115hp, you do not need any of those updates. Waste of money. If you have much bigger and more powerfull engine, you will need to do much more than that.
swakke
« Reply #7 on: August 31, 2022, 07:30:40 am »
Ok, thanks. But do you know where I can find them..
mikko k
« Reply #8 on: August 31, 2022, 11:39:58 am »
In Europe I dont know, sorry.
« Last Edit: August 31, 2022, 18:35:27 pm by mikko k » Logged
mikko k
« Reply #9 on: August 31, 2022, 18:38:15 pm »
This is best company that I know, so maybe you should ask here:
https://weddleindustries.com/
Clatter
« Reply #10 on: September 09, 2022, 15:40:29 pm »
If you have a later trans the mainshaft won’t have keys it will be splined.
These shafts have 9 teeth for 1st gear vs. 10 teeth.
3.78 ratio vs. 3.80.
This is the first upgrade you would make to a gearbox to handle power, or just to gear it for better street driving.
Since it’s a factory part, easy enough to find.
FWIW steel forks are also factory parts and found in early boxes.
A great mild street box can be made from various used transaxles with a bit of luck.
https://www.thesamba.com/vw/forum/viewtopic.php?t=770207&highlight=trevor%92s
« Last Edit: September 09, 2022, 15:45:05 pm by Clatter » Logged
swakke
« Reply #11 on: September 09, 2022, 18:51:38 pm »
Thanks for all the info. Really nice.
swakke
« Reply #12 on: April 19, 2023, 14:58:38 pm »
 Cool Cool Cool Cool
« Last Edit: April 19, 2023, 17:00:49 pm by swakke » Logged
