October 28, 2026, 17:44:29 pm
Hanibal1
Jo's 1956 barn find
Topic: Jo's 1956 barn find (Read 18312 times)
swakke
Jo's 1956 barn find
August 26, 2022, 20:32:50 pm »
Hello everyone,
I wanted to share my car with you all...
It's a 1956 VW oval that I found in a barn after standing there for a lot of years.
It's been 10 years in the making, and for the last 2 years I could drive it.
Until now... it needs some upgrades on engine, suspension and gearbox.
The engine is an 1776 cc, the output is 115 hp and 160 Nm.
I'll keep you all updated!!
Last Edit: August 26, 2022, 20:46:06 pm by swakke
VWGlassee
Re: Jo's 1956 barn find
August 26, 2022, 22:43:13 pm »
Welkom Swakke
swakke
August 27, 2022, 09:51:41 am »
Hey Yannick, thanks!!
I'm working on the gearbox for the moment... trying to make some improvements.
It's an AS version with the longer ring and pinion, that must be converted from IRS to swing axles.
Placing a stronger differential with 4 spider gears, steel shift forks and hardened keys, and stronger side covers.
For me, I can understand the improvements everyone is doing .. except from welding the synchro hubs...
But we will figure it out.. it's the first time I'm going to do this. But we never give up!!
For the moment it's lying on my workbench like this..
Last Edit: August 27, 2022, 11:56:12 am by swakke
mikko k
August 27, 2022, 17:20:46 pm »
Quote from: swakke on August 27, 2022, 09:51:41 am
When you have power enought, you will understand..
swakke
August 28, 2022, 00:19:40 am »
good quote!!
Last Edit: August 30, 2022, 18:17:57 pm by swakke
swakke
August 30, 2022, 18:18:18 pm »
Does anyone know where I can order steel shift forks and hardened keys separately?
Thnx!
mikko k
August 30, 2022, 19:35:27 pm »
If you have that 1776cc engine with 115hp, you do not need any of those updates. Waste of money. If you have much bigger and more powerfull engine, you will need to do much more than that.
swakke
August 31, 2022, 07:30:40 am »
Ok, thanks. But do you know where I can find them..
mikko k
August 31, 2022, 11:39:58 am »
In Europe I dont know, sorry.
Last Edit: August 31, 2022, 18:35:27 pm by mikko k
mikko k
August 31, 2022, 18:38:15 pm »
Quote from: swakke on August 31, 2022, 07:30:40 am
This is best company that I know, so maybe you should ask here:
https://weddleindustries.com/
Clatter
September 09, 2022, 15:40:29 pm »
If you have a later trans the mainshaft won’t have keys it will be splined.
These shafts have 9 teeth for 1st gear vs. 10 teeth.
3.78 ratio vs. 3.80.
This is the first upgrade you would make to a gearbox to handle power, or just to gear it for better street driving.
Since it’s a factory part, easy enough to find.
FWIW steel forks are also factory parts and found in early boxes.
A great mild street box can be made from various used transaxles with a bit of luck.
https://www.thesamba.com/vw/forum/viewtopic.php?t=770207&highlight=trevor%92s
Last Edit: September 09, 2022, 15:45:05 pm by Clatter
swakke
September 09, 2022, 18:51:38 pm »
Thanks for all the info. Really nice.
swakke
April 19, 2023, 14:58:38 pm »
Last Edit: April 19, 2023, 17:00:49 pm by swakke
