October 16, 2026, 17:00:52 pm
| |-+  For sale!
| | |-+  "JN2" hot type4 cam for drag or hot street by Frisiersalon Nowak
Author Topic: "JN2" hot type4 cam for drag or hot street by Frisiersalon Nowak  (Read 3353 times)
Jürgen N.
« on: September 25, 2022, 10:49:07 am »
328° type4 camshaft ( 308° @ 0,51 ) with 10.7mm cam lift from Frisiersalon Nowak ( www.frisiersalon-nowak.de ). Very sporty camshaft for big engines that live on revs. The camshaft has a very full profile and is extremely aggressive especially between 4,500 - 7,500min.
The base circle is 25.0mm, lobe center 108°.
Suitable for drag racing, circuit racing or hot street for 2.6l or larger.
The shaft is fully CNC machined, highest quality standards were realized here.
Available in solid steel and hollow drilled.
Additional features of the steel cam:
- Oil pump groove milled with finger cutter and reduced width for less clearance of oil pump drive.
Thus much more material between flange and shaft makes cam breaking impossible
- axial bearing with the correct tolerance - axial bearing seat does not need to be reworked as often necessary
- Axial bearing designed that type1 lifters can be used without reworking
- Dimensional accuracy perfectly given by complete CNC machining for all masses
- Very high level runaround, well below factory tolerance.
- Surface hardened
- Extremely tight tolerances and very high manufacturing accuracy
- All shafts are laser measured in the air-conditioned measuring room with protocol
- Q-certified according to current automotive standard IATF 16949
- 19 years of cams for type1 and type4 by Frisiersalon Nowak
- all cams in stock
Price:
„JN2“ ( 328° / 10,7 ): 429€ incl. VAT in massive steel
„JN2“ ( 328° / 10,7 ): 529€ incl. VAT in hollow drilled
