November 02, 2026, 05:59:40 am
Latest Member: thunder_bac
| |-+  Technical stuff
| | |-+  oil filter mount installation
Author Topic: oil filter mount installation  (Read 13831 times)
« on: October 01, 2022, 09:09:20 am »
I am looking at using a filter mount with a relief valve in it. CSP has it, Fast Fab has it, and scat has/used to have one. I found a scat one in my stash and now I want to use it.
but to just swap the 'regular' one for this one isn't as straight forward as first planned. so I will need new hoses (again) and a return line.
The question I have is, where do you mount it? how do you mount it? and can the filter be horizontal? that is actually 3 questions... pictures are appreciated preferably in stock cars, but anything is appreciated (that's 4.)
« Reply #1 on: October 01, 2022, 13:25:09 pm »
I mount them same place as usual, filter mount can be any angle you want but if its not vertical it makes a real mess when changing filter!!
« Reply #2 on: October 02, 2022, 17:22:21 pm »
good point, I need to think about that. I am going to mount it.
the return is best to the sump?
« Reply #3 on: October 03, 2022, 00:39:06 am »
Yep in sump to get oil back to where it needs to be
johandryselius
« Reply #4 on: October 03, 2022, 14:38:26 pm »
Nicolas!
I have it mounted exactly as Richie describes it and it works perfect.
Johan
1600cc Challenge Porsche 356:
1600cc Challenge Buggy:
Europes quickest ProStock VW:
« Reply #5 on: October 05, 2022, 07:23:51 am »
I will do that (I am the kind of guy that always stains the fresh new t-shirt right away) so upright it is.
I will be moving it away from under the left fender. I feel that with the top mounted entrance and exit the mount will be too low. and I figured out that it will be a lot better if I make a catch tray to have that filter IN it... do you use a bracket on the exhaust or where/how do you place it. I seem to have issues with clearance from the exhaust all the time. I will get around it. pun intended.  Grin
« Reply #6 on: October 05, 2022, 09:53:47 am »
Out the top with mixture of 90 & 120degree AN-8 fittings works from what i remember with the Scat version
