August 13, 2026, 09:49:53 am
| |-+  For sale!
| | |-+  2332 engine
Author Topic: 2332 engine  (Read 2694 times)
stussyrich
« on: December 18, 2022, 21:41:37 pm »
old faithful from lil stink hound.   long block only.
2332cc 10.1:1 COMPRESSION RATIO.
Autolinea alloy case : Full flowed, stroker clearance,  10 mm Chromoly stud kit, 15mmX10mm head nuts high strength, shuffle pinned drilled tapped oil galleys.
-CRANK: CB 84 MM wedge mated forged Nitrited & counter weighted, 8 dowel, chevy journals with allen plugs, bug pack straigt cut gear set, chromoly 11/32, 8 Dowels.
-RODS: Scat H beam 5.5 length with HD ARP bolts torqued to 30 LB, chevy journals stroker clearanced & balance
-CAM: Web cam 86c with Bug pack straight cut gears set at top dead center, dual thrust cam bearings,
-LIFTERS: Heavy duty hardened performance lifters clearance for perfect fit CB
-PISTON KIT: Wiseco pistons and mahle barrels stoker set with EMPI heavy duty C clip rist pin retainers, total seal gapless #2
-HEADS: brothers large ovals. ported and custom polished finished 42X37.5 HD dual springs tinatium retainers, and keepers.
-ROCKERS: CB 1.4 ratio rockers
-PUSH ROD TUBS AND PUSH RODS: Stainless steel push rod tubs Windage, Chromoly 4340 3/8 strength Manton push rods cut to length w/ super cooling tin.
-FlYWHEEL: Chromoly lightened flywheel 12LB, wedge mated, 11/32 8 Dowels, Kennedy stage 1 pressure plate w/cush lock disk, SCAT chromoly Gland nut with washer
-PUMP: 30mm Shadek pump w/CB anodized black pump cover
£5000
« Last Edit: January 07, 2023, 21:40:18 pm by stussyrich » Logged
Lil Stink Hound.. 2332 IDA. 11.78 @ 112mph.
Turbo Notch.. 2332 Turbo 10.2 @ 137mph.
