October 04, 2026, 08:10:27 am
352313 Posts in 28957 Topics by 6925 Members
| | |-+  Can this head chamber be modded for more CC?
Author Topic: Can this head chamber be modded for more CC?  (Read 26346 times)
« on: August 30, 2023, 00:33:45 am »
Hi all,
It’s late, I am over thinking and this may be total rubbish, but I have a pair of Comp eliminator heads that have a 33 cc chamber. Originally I wanted them for a high compression ratio N/A motor but now have plans to go turbo. Could my chambers be modified to gain cc by unshrouding the valves more? Thanks in advance!
Lee
PPRMicke
« Reply #1 on: August 30, 2023, 08:27:35 am »
when the chamber is so small and you have to increase to around 65 cc, there is too little material so it wants to crack
/// Micke
mikko k
« Reply #2 on: August 30, 2023, 09:29:33 am »
You can make those chambers a little bigger. But you will need pistons that have chambers also.
Make those heads first, then you know how big they will be and then order suitable pistons.
« Reply #3 on: August 31, 2023, 12:13:44 pm »
Thank you both for the replies
Lee
« Reply #4 on: September 15, 2023, 15:32:38 pm »
Can't you weld the heads and flycut them again?
mikko k
« Reply #5 on: September 15, 2023, 19:08:28 pm »
That much welding takes hours of work. And after that, new valve seats because they get too much heat.
Welding doesn’t make any sense. Heads will be really expensive..
