October 04, 2026, 08:10:18 am
Can this head chamber be modded for more CC?
Topic: Can this head chamber be modded for more CC? (Read 26343 times)
August 30, 2023, 00:33:45 am »
Hi all,
It’s late, I am over thinking and this may be total rubbish, but I have a pair of Comp eliminator heads that have a 33 cc chamber. Originally I wanted them for a high compression ratio N/A motor but now have plans to go turbo. Could my chambers be modified to gain cc by unshrouding the valves more? Thanks in advance!
PPRMicke
Re: Can this head chamber be modded for more CC?
August 30, 2023, 08:27:35 am »
when the chamber is so small and you have to increase to around 65 cc, there is too little material so it wants to crack
/// Micke
mikko k
August 30, 2023, 09:29:33 am »
You can make those chambers a little bigger. But you will need pistons that have chambers also.
Make those heads first, then you know how big they will be and then order suitable pistons.
August 31, 2023, 12:13:44 pm »
Thank you both for the replies
September 15, 2023, 15:32:38 pm »
Can't you weld the heads and flycut them again?
mikko k
September 15, 2023, 19:08:28 pm »
Quote from: Peter on September 15, 2023, 15:32:38 pm
That much welding takes hours of work. And after that, new valve seats because they get too much heat.
Welding doesn’t make any sense. Heads will be really expensive..
